Question about DISH Network 625 Duo DVR Receiver (Remanufactured)
Need remote tv code for 42 inch Vizio tv? - DISH Network 625 Duo DVR Receiver (Remanufactured)
Posted by mfpatric on
Cheri Torres
  • DISH Network Expert
  • 146 Answers
Hey there, Cheri Torres with DISH network Customer Service here. I came across your post recently and wanted to help. We have a few different codes for each of our different models of remotes. The model number of the remote will be located on the back of the remote on the top usually a 2 to 3 digit number with a decimal point. I will list here for you the more popular models of remotes as well as the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any further question or concerns feel free to reach me at [email protected]
Remote codes for Vizio TVs.
3.0, 3.1, 3.2, 3.4 IR remotes - 505, 671, 627, 520 and 766
5.0, 5.2, 5.3, 5.4 IR remotes - 627, 505, 506, 457, 111, 520 and 766
4.0 and 4.4 IR/UHF remotes - 505, 627, 555 and 766
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 627, 505, 678, 825 and 520
20.0 IR and 21.0 IR/UHF remotes - 505, 598, 502 and 627
Instructions for address the remote to the TV.
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all the mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Posted on May 10, 2011
I have a 42 inch Vizio tv, 7 years old. The menu button will not work although other buttons, like volume button does. Why would menu button not work?
I have a similar issue with my 10 year Vizio 42", it is the infrared receiver in the TV that is the problem (tried other remotes).
Dec 02, 2016 | Vizio Televison & Video
Reprogram the URC-9910 universal remote for VIZIO E3D420VX
Universal remote code to check with Vizio TV is [0081.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
Dec 30, 2012 | One For All URC-9910 LCD Remote Control
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
DISH Network 625 Duo DVR Receiver (Remanufactured) Logo
709 people viewed this question
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
