Question about Sony Playstation 3 (PS3) Console
Always 8 letters
No matter how much numbers i type it only shows 8 of them.... My wpa key is 10 letters long...I type all 10 press enter and it shows only 8 of them... So this is a problem, because i can't get to the wireless acess point. Plus I have to type PPoE user name and password, password is 7 letters long, but again then it's shows 8 letters and everything fail- wrong password. So how can I make ps3 showing what I write??? Plz help
Posted by Nedostopna on
5 Related Answers
Anonymous
SOURCE: Setting up a Wireless Internet Connection on the PlayStation 3
lol
Posted on Jun 20, 2008
drlalitv
Lalit Varadpande
  • 488 Answers
SOURCE: PS3 WEP Key Problems
if its asking for a WEP key then your wireless network is a secured one..you will need to put the same key as you had originally used while setting your wireless network..are you able to connect to the wireless from a laptop?
see the message that comes on your ps3 when you scan for available networks..you will know if your wireless has security..
you can chnage the security of your wireless by logging oto it by typing 192.168.1.1 in the laptop browser and then configure/change security settings..hope it helps..
Posted on Oct 30, 2008
Anonymous
SOURCE: PS3 can't detect access point
i have some solutions..
1. if there's lots of walls between the router and your ps3 it may not detect the signal. i had a very weak signal until i moved some stuff around.
2. you can manually type in your wireless name and i think it should at least reconize it, and maybe connect.
3. make sure theres no firewalls or anything to block other connections from entering your signal.
thats all i can say, sorry im not a tech guy-only 17!
Posted on Dec 27, 2008
SOURCE: my ps3 shows nothing but background waves, wont load main page
unplug PS3. Wait 10 minutes and turn on.
do the same with the power supply.
Posted on Aug 31, 2009
Anonymous
  • 7 Answers
SOURCE: my ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to http://192.168.1.1 or .0.1 and log in and chang the settings to default
Posted on Sep 27, 2009
Testimonial: "i called belkin and they had me reset the router to original settings. the address admin942 gave was very helpful. thank you!"
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
How do i set up netgear to recognize kindle fire
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.0.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and password for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply.10. you can now restart your kindle then try to search for wireless networks again and when you got your netgear wi-fi name press connect.11. you will be asked to enter your WEP key or your Pre-Shared Key.12. enter your password that you use in the instruction number 8, then press OK, then you are good to go.
Dec 25, 2011 | NetGear Computers & Internet
How to set router password
Make sure that you are connected via ethernet cable or hard wired connection:
1. Open a browser ( internet explorer, mozilla firefox,google chrome or safari)2. Delete all of the characters in the address bar3. Type the numbers 192.168.1.14. Press enter.5. You will be able to view the modem settings page.6. Select Basic Setup or the second tab with the word interface.7. Select Wireless Setup8. Enter the SSID or (service set ID), this will be your wifi name.9. Select WEP or WPA for your router's wi-fi password.10. Select ASCII for the passworrd.11. Enter any password ( around 10 alpha numeric characters to make sure that it is a strong password)**alpha numeric means combination of letters and numbers.12. Select Save or Apply.13. Disconnect the network cable for you to test the Wireless password connection.14. Scan for new wireless network on the lower left hand of your computer's screen.15. Look for the wireless name that you entered for your SSID.16. Connect and it will ask you for the wireless / pre-shared key17. Enter the WPA password that you created ( the 10 letters and numbers that you entered for ASCII)18. Press connect.
there you go... you will be connected to your router via wireless with password protection. No one can connect to your router unless you gave them your PSK or wi-fi pre-shared key.
Dec 24, 2011 | Linksys Computers & Internet
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
Ive set up my wep and my wpa psk,i then take a connection test,and it always comes up error code 51330
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Feb 09, 2010 | Nintendo Wii Console
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
Error code 51330 on the wii.it will not except my
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
When entering a WPA key in the network settings of my HP OfficeJet 6480, how do I toggle from letters to numbers?
When you enter the WPA key, use the appropriate key on number keypad on the front panel. Keep pressing the appropriate key until the desired letter (upper or lower) appears.
Once the correct letter is displayed, wait a second or two and the cursor will move to right so you can enter the next letter or key.
A second option is to connect the printer to your using the wired connection and then open the web interface using the ip address of the printer. Login to the printer then go to the wireless security settings and enter the Pre-Shared Key (WPA key).
It's also a good idea to put a check mark in the "Obscure PSK" option box as an added security measure.
Jun 04, 2009 | Digital Products Hewlett Packard OfficeJet...
Wireless is not secure
Step 1 Log into the Router
A device which forwards packets between networks. The forwarding decision is based on network layer information and routing tables, often constructed by routing protocols.'); return false">Router
by entering it’s IP address into a browser. The default IP address is http://192.168.1.1. At the login, enter your username (admin) and password (admin).
Step 2 Click on “Wireless” on the left hand side then click on “WEP” at the top of the page.
tew-432brp_f_1.jpg Step 3 Enter in the desired encryption values then click “Apply”.
Examples:
Authentication type:WEP WEP
Type: Open
System Mode: Hex WEP
Key: 64-bit Key 1: 0000000000
Note: For WEP you can choose ASCII or HEX modes.
64bit ASCII = 5 digit ASCII key.
64bit HEX = 10 digit HEX key. (Can only use letters A~F and numbers)
128bit ASCII = 13 digit ASCII key.
128bit HEX = 26 digit HEX key. (Can only use letters A~F and numbers)
You can also choose WPA
Wi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA
-PSK. The key must be between 8~64 digits.
Authentication type: WPA
-PSK
Passphrase: omg laserbeams pew pew pew
Confirm passphrase: omg laserbeams pew pew pew
Jan 05, 2009 | Trendware TEW-432BRP 54Mbps Wireless...
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
