Question about Senco PC1010 1/2 HP 1 Gallon Mini Air Compressor
That is the safety relief valve which means it has gone bad or you need to turn back the high pressure setting about 5 t0 10 psi. When this happens again there should be a small pin in the middle of it that has a metal ring through it. When it goes off push on that pin and if the air coming out stops or shuts off then you need to turn back the psi if not the valve needs replaced.
Posted on May 09, 2011
Jun 04, 2018 | Senco Air Tools & Compressors
Oct 25, 2016 | Lincoln Cars & Trucks
Dec 30, 2013 | Ridgid FactoryReconditioned 12 HP 5Gallon...
Jul 17, 2011 | Air Tools & Compressors
Oct 29, 2010 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Aug 26, 2010 | Air Tools & Compressors
Nov 13, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Nov 12, 2009 | Campbell Hausfeld 28 - Gallon Air...
Jul 04, 2009 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Mar 18, 2009 | Makita Air Tools & Compressors
Sep 27, 2016 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
788 people viewed this question
