Question about Texas Instruments TI-30XA Calculator
How do you find the log of 9.01 using TI 30xA calculator?
Posted by angie0428 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
To calculate the common (base 10) log of 9.01, press 9 . 0 1 LOG =
To calculate the natural (base 3) log of 9.01, press 9 . 0 1 LN =
Both the LOG and LN keys are on the top row of the keyboard.
Posted on May 09, 2011
Change log base
The TI-30XA calculates logarithms to base e and base 10. You can calculate the log of x to any base b by calculating the logarithm of x and dividing it by the logarithm of b: log(x)/log(b) or ln(x)/ln(b).
Nov 29, 2013 | Texas Instruments TI-30XA Calculator
How to fix error mesage on TI-30Xa. Every time I press LOG an error sign comes up. how do i fix this?
To take the log of a number, enter the number then press the LOG button, then the =. To take the log of a negative number, enter the negative number using the +/- key just to the right of the decimal point. To calculate the negative of a log, calculate the log and then negate it using +/-. To calculate the antilog (inverse logarithm), press 2nd then LOG.
Bear in mind that LOG is the common (base-10) logarithm. For the natural (base-e) logarithm, use the LN key to its right.
Nov 07, 2011 | Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
How do you use the -log function on the TI-30XA calculator? I downloaded the manual and there is no instruction for finding the -log of a number
Do you mean the antilog? For the common antilog, use the shifted function of the LOG key (marked 10^x). For the natural antilog, use the shifted function of the LN key (marked e^x).
For example, to calculate the common antilog of 0.5, press . 5 SHIFT [10^x] = and get about 3.16. To calculate the natural antilog of 0.5, press . 5 SHIFT [e^x] = and get about 1.65.
Mar 29, 2011 | Texas Instruments TI-30XA Calculator
Lost instruction on how to use ti-30xa calculator.how to do square root/percent/ratio/proprtion/roots/log
Here is the link to the calculator manual. It will show you how to do square root calculations, percentages, other roots, and logs. As to ratios and proportions you will have to read your mathematics textbook.
Aug 26, 2010 | Texas Instruments TI-30XA Calculator
I need to use a TI 30Xa to evaluate a Logarithm Log5 1/625 Not sure how to use the TI to do Log5
Use the relation log5(x) = log(x) / log(5) = ln(x) / ln(5)
LOG ( 1 / 625 ) / LOG 5 =
or
LN ( 1 / 625 ) / LN 5 =
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
Natural logarithm with TI-30XA calculator
I noticed that this calculator doesn't have a natural logarithm function as well. You can can always use the fact that
ln x = (log x) /log e or since log e is approximately .43429482
ln x = (log x)/.43429482. The greatest solution and it might be worth the 15 bucks or so to get a calculator with e^x and the natural logarithm function.
Feb 20, 2009 | Texas Instruments TI-30XA Calculator
TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
Dec 10, 2007 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
311 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
