Question about Apple AirPort Extreme Router
I have a netgear wdn3700 as router, airport express with 7.5.2 works, airport extreme will not connect to my network, want airport extreme to extend my network without being part of a wds. Setup connecting to my network. When my mac power book is connected to one of the ethernet ports, I have no connection. Doing this with airport express i get a connection on my mac. Where is the difference between express and extreme. Thanks Ted
Posted by ted6697 on
  • Ewe Jin Yeap
    Ewe Jin Yeap May 10, 2011
    How is your Airport Extreme connected to the WDN3700?
Darryl Sismil
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
Use your airport utility, it will guide you thour the setuo, remember, gate way or bridge. you need both, but you need to choice witch one.
Posted on Jan 21, 2014
5 Related Answers
Anonymous
SOURCE: Cannot get a PC to connect to my Airport Extreme BS
I had trouble connecting my PC to an airport network that my mac was working just fine on. I found this forum to get an "equivalent network password" and it worked great. The pictures were helpful too. Go to the Airport Utility and Then the "Base Station" header on your mac. Then select "Equivalent Network Password". It will be super long and lots of letters and numbers. Worked for me! Here is the forum: http://support.apple.com/kb/HT1790
Good luck, hope this helps!
Posted on Jul 02, 2009
Anonymous
  • 123 Answers
SOURCE: Can you get a different ip address for a laptop
Sure all you have to do is go to ipcomfig re;ease your ip addresses and renew. Once you do this the router should assign a different ip address.
Let me know if you have any problems.
Deathstalker
Posted on Aug 22, 2009
jgcalifornia
JG1977
  • 160 Answers
SOURCE: Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Posted on Aug 26, 2009
Anonymous
  • 67 Answers
SOURCE: Internet connection drops within 5 min after (re)booting Airport
Speak with your internet provider, it sounds to me that the apple people didnt know what the problem was without getting down and dirtyy with it so they replaced it hoping for an easy fix. Seems to me that either the internet signal is being interrupted between the isp and your home .. or the motorola modem is having problems. I have never been a fan of motorola modems to begin with. Also the rentals u get from cable companies are used.. and typically subpar bottom of the line equipment that fail often. IF you think you will be using cable internet for years to come, purchase a linksys modem, as it is you are paying $3-5 a month for the rental of the modem. But I digress, speak with your isp and see if they cant troubleshoot the problem.. if 2 airports are having the same problem the chances of it being the airport... slim to none. good luck with all of this post again if nothing changes.
Posted on Aug 31, 2009
kid_ant
kid_ant
  • 881 Answers
SOURCE: Airport Extreme, Mac Cube and proposed Blue Ray /WIFI
Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
Here's a quick setup guide from Apple.com:
Setup Airport Extreme
Posted on Jul 23, 2010
Have to reset wireless access point several times a day
Make sure it's not getting too hot. That is usually the problem.
Mar 21, 2014 | NetGear R6300 WiFi Router
My iPad won't connect to Airport Extreme WiFi
Is your A P E a hidden network?, if so just type in the name of your router name and scan, it will find and ask for a password
Apr 28, 2012 | Apple AirPort Extreme Router
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Extreme Router Logo
295 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
