Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
I can't install a 500gb western digital sata drive to my vpm800-m2 motherboard it won't read the drive
Posted by rpcomserv232 on
Art Ellison
  • 2,229 Answers
When you install the drive, go to "Computer" or "my computer" and right-click on the icon.
From the dropdown menu, choose "manage".
Click on Disk Management. You will see your C: drive there and it will tell you what it is.
You will probably also see the new drive, but it will appear as unknown. You can right-click on it to initialize it and format it if it is not formatted.
There you go.
Posted on May 09, 2011
Will K8MM-V MS-7142 Motherboard supports 500GB/250GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forwardforward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI Ms-7142 k8mm-v Mainboard Ide - Socket...
Will K8MM-V MS-7142 Motherboard supports 500GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI K8MM-V Motherboard
Can I put this HDD --Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive IN asus k8u-x
Yes, you can connect that hard drive to that motherboard. However, it is worth noting that the maximum transfer speed of the motherboard is only 3.0 Gb/s, so you will not be able to get the full speed from that hard drive.
They will work together when connected with the correct SATA cable.
Hope this is helpful!
May 10, 2011 | ASUS K8U-X Motherboard
I have a 320 as my primary and i want 2 ad a 500 sata wd how do i set the pin jumper for secondary on my new one and the factory 320 has no jumper at all thanks
The SATA Drives do not need jumpers to set primary and secondary drive positions. Each sata drive gets it's own connection to the motherboard. Check you motherboard diagram, and make sure the 320GB drive is plugged into the 1st sata controler, and that the 500GB drive is connected to the 2nd.
Oct 11, 2009 | Western Digital Caviar 500GB Internal SATA...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
External Hard drives
I will recommend you to use Western Digital I my self alos using a western Digital and its very reliable to use , So I will go for buying that one and it will be a big help for you...
Hope that helps.......
Aug 18, 2008 | Computers & Internet
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
151 people viewed this question
Top VIA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Atiq
ChinthakaJ
ChinthakaJ
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
