try a different electrical outlet. turn it on and set it at highest reading then reduce the setting to the lowest.
if still not running, unplug it and fiddle with the high level
contact or switch on the bucket. seat the bucket properly then plug it back in to test if it works.
I just got one from a friend of mine and we dont have a manual so i went to the honeywell site typed in the code HDH-165 and it comes back with nothing. kinda frusterating as i need my place to be cool and was told by gettong one of these it will take the mold smell and tthe heat out.
Hi, There are many reasons why a dehumidifier willnot work or collect water. Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
The most common cause of frost and ice buildup on a dehumidifier is
because the unit is operating in temperatures that are too cold. Many
dehumidifiers are not equipped to run at temperatures below 65 degrees
Fahrenheit. To fix this problem, Position the dehumidifier in an area where there is at least one foot of
clearance around the unit in order to allow for proper air circulation
during its operation. Close all windows, doors and other outside
openings to make sure your unit isn't attempting to remove moisture from
areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or
by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the
electrical source and check the filter by opening the filter
compartment. If the filter is dirty, it will restrict airflow through
the unit and lead to freezing. Soleus recommends lightly vacuuming the
surface of the filter to remove dirt. The filter also can be washed in
warm water if it is extremely dirty. Once clean, place the filter back
in its compartment. Allow for the ice to melt and then restart your
dehumidifier.
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
