Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
Posted on May 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the length of time for the Normal Wash cycle on the Undercounter Elite model? Mine seems to run about 2 hours. That seems way too long to me.
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on May 10, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835315
Points
101584
Nah... that is about normal for a dishwasher today....if all else fails just soak everything to death... no real cleaning anymore...
heatman101
1helpful
How long is the light wash cycle suppossed to run and does the options cycle need to be run too? i have put my machine on light cycle and it runs back and forth from sensing to wash .. stops and goes back...
Hello, Thank You for using FixYa. I will be helping you today.Yes it is normal. The length of the cycle depends on the water temperature entering the unit and the options selected. The unit has a sensor that checks the water constantly until it is clean. A normal cycle on this unit with options selected can last two hours. And stopping the unit and opening the door extends the time also.
Thank You and please rate my answer if it was helpful..
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
3helpful
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
1helpful
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
I have a kenmore elite washer and dryer is there any way to speed up the time it takes to do a load of wash it takes mine forever. Can it be reprogrammed or a way to reduce the time it takes for a wash...
No way to change pre programmed main control board, although you can use a gentle/delicate cycle that does have a shorter wash time. I would not use this for very dirty laundry. Good Luck, Appliance Specialists
6helpful
4answers
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
1helpful
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
