RCA Lyra M2104 MP3 Player Logo
A
Anonymous Posted on May 09, 2011
Music only plays on right side of headset. changed headset but have same problem
Nash delos Santos
Level 2:
Sergeant:
  • Expert 172 Answers
  • Posted on May 09, 2011
Nash delos Santos
Expert
Level 2:
Sergeant:
Answers
172
Questions
0
Helped
53985
Points
536
Sounds like you have a problem with your audio port. Try to loosen the connection of your headphone and see if it changes anything. If it does then that's where the problem is. Probably loose connection or something's shorting it.
2answers
My headset just stopped playin sound???
If the stereo earphone output socket is in tact (not broken), most likely the problem maybe the Earphone-cord is broken.
tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 • Computers & Internet
1helpful
Right side of headphone stoped working
you need to open the broken side up and re solder the cable back also check the other cable to see if it hasn't sheered off inside the insulation like mine did. Hope this helps. J
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Having sound problem in my laptop after i got plug in the headset , but the sounds coming through the headset but vice versa in laptop
Go to Control Panel >> Sound >> Play back tab >> Right click on Speaker and set it default.
Connect Headset >> Play any music >> As soon as the music started, remove the headset with a slight ****.
Restart Audio services if issue is same and then update the audio driver.
Start search >> services.msc >> right pane, double click on Windows Audio >> Stop >> Start >> Startup Type: Automatic.
Update the drivers
3helpful
2answers
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
3helpful
Music trouble
Not all bluetooth headsets can play music. If you hear music on your headset when you close your phone then your bluetooth is set for it. If not, you are unable to use that bluetooth for music.
4helpful
2answers
Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
1helpful
Bluetooth headset won't play music
hello,
All the bluetooth wireless headset are only capable of making/receiving voice calls.
Y?
its a bluetooth software which is installed on ur cell phone. it is not capable of listing the music through the BT headset. BT 1.1 Software version only lets you listen to mono.
BT 1.2, Version playing music through a BT headset while music is playing on laptops.
and again we need to find out what BT software version is on the phone and if sony erricsson came out with better BT software for your needs.
hope this little information helps.
TY
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
