F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes Lid not closing. ??¢ Overfilling. ??¢ Foaming. ??¢ Not draining. ??¢ Lid seal damaged. ??¢ Dispenser or water softener or their seals leaking. ??¢ Damaged water inlet or drain hoses. ??¢ Leaking heater plate or motor seals, or drain o-ring seals. ??¢ Yoke jammed or broken. ??¢ Inlet hose to inlet valve connection loose. ??¢ Inlet valve body leak. ??¢ Heater plate damage (chipped enamel). ??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
