Question about Linksys WRT160N Wireless Router
My iMac is blocked from time to time - Linksys WRT160N Wireless Router
Posted by gerfer79 on
Ewe Jin Yeap
    New Friend:
  • 50 Answers
It happens to Macs sometimes. To get around the problem, you could try setting a Static IP.
Posted on May 09, 2011
How do I disable web guard on imac computer
Depends on the browser you're using. Check your preferences in Safari & make sure 'enable plugins' is checked. If you have any extensions downloaded the make sure it doesn't block access to the sites you're referencing. You can also try firefox as an alternative browser. Good to have an alternative just in case.
Jun 04, 2015 | Apple 24" iMac Desktop
How do I take apart my imac?
It's for advance users only because you need special screw drivers and previous experience to open an iMac. I have seen alot of time when new users open iMac and broke the lcd connector. So I advise to be very careful as it may cost you more in the end. Thank you and good luck. Tech from
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Sep 06, 2014 | Apple 24" iMac Desktop
Blocked plugins
10.6 and older no longer support flash, if you can not upgrade you to OS 10.7 or newer you are stuck.
Jul 24, 2013 | Computers & Internet
I'm having some problems with my Imac G5. It crashed a long time ago, so i added a new hard drive, and am now attempting to install the OS again. i believe it's 10.3. It will install the first install...
I have to assume that you mean you REPLACED the hard drive, as there is no room for two drives in an iMac.
If I had this machine in my shop, I would start by resetting the SMU (there are several models of iMac G5, each with a different procedure) and then resetting the PRAM at boot by holding down command-option-P-R until I got the boot chime three times. Then I would boot it from an external OS drive and run DiskWarrior over the internal drive to straighten out any file system corruption. Or, if the drive is brand new, I would erase and format it with "write zeroes to all records once" just to verify the drive and map out any bad blocks.
Then I would try the installation again. When the machine rebooted, I would hold down command-V as I heard the boot chime, just to watch the console messages in real time and see what appears at the point of hang, assuming it continues to hang. From that point, I would be able to diagnose more about where to look for the problem.
Thanks for the detailed report by the way. I apologize if my plan of action involves a lot of accessories you don't own, but the fact is you don't have a trivial problem to diagnose here.
Oct 29, 2010 | Apple iMac G5 Desktop
My imac safari can no longer open google. it can open yahoo and maps at google but wont allow google searches. i have tried to reset and empty cache and I checked the keychain passwords. still no luck
look at the browser tools at the options ..under security ..or interdictions ...Im not sure at Mac ...it is for sure added by mistake on the list with blocked sites..
Apr 27, 2010 | Apple iMac G4 20" Mac Desktop
Thanks for the help!
That sounds like it would fix it. Have you recently updated the memory in the imac? It may be incompatable. Otherwise it may simply have become faulty over time.
Please make sure that before you open up your imac, you're not voiding your warrenty. I know that the aluminium imacs allow this, but i dont think the G4 versions do.
Hope this helps,
Nathan.
Apr 13, 2009 | Apple iMac G4 Desktop
Linksys WRT160N Wireless Router  Logo
Top Linksys Computers & Internet Experts
Ekse
Mike
Jeffrey Groves
Jeffrey Groves
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
