To reinstall the glass door buffers on your Hotpoint oven model ShY23X, you can follow these steps:
Gather the necessary materials: Make sure you have the glass door buffers and any accompanying screws or fasteners required for installation.
Identify the correct position: Take a close look at the oven door and identify the areas where the glass door buffers should be installed. Typically, there will be corresponding holes or slots on the oven door where the buffers fit.
Align the buffers: Hold one glass door buffer in your hand and align it with the corresponding hole or slot on the oven door. The buffer should fit snugly into place.
Secure the buffer: Once the buffer is aligned properly, insert any screws or fasteners through the designated holes on the oven door to secure the buffer in place. Use a screwdriver or appropriate tool to tighten the screws, ensuring the buffer is firmly attached.
Repeat for the other buffer: Follow the same process to install the second glass door buffer on the opposite side of the oven door. Align it with the corresponding hole or slot, insert the screws or fasteners, and tighten them to secure the buffer.
Test the door: After both buffers are securely installed, gently close and open the oven door to ensure it operates smoothly. Make sure the door closes completely and the glass door buffers are providing the desired cushioning and support.
It's not only for You..While watching Videos Online the Internet speed get slow ...Also the Online videos buffer and display in screen..So you can better pause the Video in Youtube after select the video.Then you can see a buffer lines scroll through end.After that You can play it.You can watch it without buffering.You can check the speed of the internet at Scanmyspeed. com here You can check the speed in Mbps and MBps.
It sounds as if your buffer is filling up. The buffer is where the camera temporarily stores images before writing them to the memory card. If you're shooting RAW, try shooting JPEG and see whether you can shoot longer bursts. If so, it's definitely a buffer problem. Another thing that will help with the buffer is to use a faster memory card. Use a SDHC card that's rated at least Class 6 (there will be a circle with a number inside marked on the front of the card).
