Question about Toshiba SD-43HTS System
Good day , my problem is that my system is working perfectly when I am using my DVD, however it is not working when I am watching TV. I am using the Digital Audio out from my TV to my Digital audio in of my HTS. It used to work even recently. Is it possible that I press the wrong buttons on my remote control ? Thanks in advance. Daniel Laprade
6ya staff
SOURCE:
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Posted on Aug 27, 2007
Anonymous
SOURCE: Desire Audio for Theater System when watching Tv.
make sure all the things are hooked up to the tv right and on the remote push function.. i can watch tv with the sound and picture like this...
Posted on Feb 03, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
Anonymous
  • 320 Answers
SOURCE: No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Posted on Nov 11, 2008
Anonymous
  • 21 Answers
SOURCE: No Audio Output Device Installed - Toshiba M600 Portege
Maybe the problem is in your BIOS, you might need to enable something. Or maybe the CMOS battery is was going bad, and now it's shot, so your system doesn't remember it's settings.
Posted on Feb 26, 2009
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
Basic cable connections using rear coxial connection
better call your cable tv provider.it seems that the problem is out of your premises
Jan 13, 2009 | JVC AV-56WP74 56" Rear Projection...
The sound went out while watching a program on the set.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
Sep 28, 2008 | RCA D52W136D 52 in. TV/DVD Combo
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Phillips Home Theatre System
Did you try un-plugging all cords, turning off power to that circuit, or indivisually disconnecting all electrical cords from each component that has no sound emmitting from it. This procedures sometime or some how reboots the audio or video component to its original setting. Good luck Sir.
D. White
Nov 13, 2007 | Televison & Video
Toshiba SD-43HTS System Logo
47 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
