Question about Dishwashers
Jenn-Air DW860 diswasher loud motor noise
Hi Mark,
My diswasher is making a loud humming noise when I turn it on. The last time I used it was to clean new dishes, and I suspect a price sticker may have come off. My husband is handy. Does he need to pull the diswasher out of the wall or how can he get to the pump? Any guidance you can give us would be appreciated. Thanks!
Posted by Elorach on
5 Related Answers
Anonymous
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
Michael Grimshaw
  • 131 Answers
SOURCE: Loud Humming Noise
You're describing vague, conflicting information. At first glance, I would think you have something stuck in the pump. But then it would be there in the rinse-only cycle also.
The anti-bacterial mode heats the water up to about 180F. This kills bacteria, and it also speeds up the action of the detergent. It could be dissolving whatever is in there.
The humming noise wasn't there in the rinse mode... The heater isn't on in the rinse mode - everything else is. But I've NEVER heard a heating element hum.
Cleaning the filter:
The filter is in the back in the bottom right. It's cover is held on by two 1/4 in screws. Under that is a large grate, and I sometimes find stuff clogging the screen (underwater, toward the center of the machine.) I'd start by looking there.
Posted on Mar 24, 2008
Anonymous
  • 338 Answers
SOURCE: My kitchenaid dishwasher is making
if the water is not spraying you may have a seized up motor. if the water is spraying then you have something down in your motor somewhere..
Posted on Dec 25, 2008
Anonymous
SOURCE: Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Posted on Apr 06, 2009
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: when starting washing process machine
your motor has failed....will need to be replaced
Please give rate/vote on this response thanks
Posted on Dec 19, 2010
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
It fills & dumps the water with no problem BUT it will not wash the dishes it just makes a humming noise.
OK, i would test the motor to make sure that it is working properly. this is a two speed motor and, if the windings are bad or separating, it will not be able to switch speeds. if the motor checks out ok, this will confirm control failure. replace timer or control board in this case.
May 29, 2009 | Kenmore Dishwashers
good luck!
Mar 29, 2009 | Jenn-Air Dishwashers
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Loud humming noise when in use
We had this problem with a new GE microwave in our last home. GE service replaced fan assy,.AND added rubber foam around the motor, Loud hum was reduced,but never did completely go away. We learned to live with it/
May 31, 2007 | GE JE1640 Microwave Oven
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
