Question about GE Washing Machines
I have always bought GE and have had good luck except with my recent purchase of a washer model #wlsr2200j3ww. at lowes.. We have already had a tech out , It just makes to much noise while washing a load and the tech said we just had to except that...I could not believe this and that nothing could be done about this problem? Linda
Posted by lindasea on
J Rosado
  • 1,163 Answers
Return it to Lowe's if it's recent enough
Posted on Nov 11, 2017
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Posted on Dec 01, 2006
Anonymous
SOURCE: loud noise while agitating in wash cycle
I have the same problem, loud plastic squeak/grind when agitating only. I'd like to fix it, but have never taken apart a washing machine.
The advice below sounds good but where do you start with "begin dissassembly from the tub down"....etc. Anyone have a good internet resource with images for disassembling this machine?
Thanks.
Posted on Mar 16, 2008
Anonymous
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Posted on Sep 14, 2008
Anonymous
SOURCE: I purchased the Frigidaire stackable
Your power supply has failed, need part # 134409904, check ebay, about $70
this board is in a white plastic box with wires running to the motor, access from the back of the machine, maybe say magnetek on it 4246-99-1
Posted on Jan 22, 2009
Anonymous
SOURCE: Walking during the spin cycle
My GE front load washer model WCVH6800JBB have the same problem. I just purchased and installed it yesterday, 05/04/09. Just like everyone said... when it got to the spinning cycle it walked to the middle of my garage and all the connections in the back of the machine fell off. My husband checked the instruction... There are 4 nut bolts in the back of the machine near the rubber leg (level). You need to take them off and try to balance your machine again. My washer is running very smooth now. Good luck!
Posted on May 05, 2009
Door lock mechanism replacement
1) Will follow with reason to get hold of company or person who did prior repair.
2) Not familiar with this one.
3) When people more specific then help is a lot easier.
3a) That being said; Hopefully that you have a fix it warranty.
Large home appliances can pay off.
4) My problem was with a Whirlpool top loader. (The newer type with the 4" high impeller.) Machine made noises and had an error code which couldn't be reset. (Powered machine off/on a coupe of times.) Plus the clothes were always soaked and needed to be hand wrung to dry. Couldn't see why as the lid latch prevented opening to watch progress of cycle. (Development of the newer technology.) Had purchased the washer at Lowes. (And for once the extra warranty. A friend's suggestion.) 14 mos. after new the problem occurred. Called Lowes. A repairman came out and being as he had had repetitive faults he went under the machine and tightened the motor's hub nut which was lock washered. 5 days later the problem re-occurred. Called Lowes. They sent a different repair tech next day. This one did the same repair but added a substance (Loc Tite) before he tightened the nut. Loc Tite goes on as a paste or gel then semi hardens to form a lock washer effect by preventing the nut from backing off. That on top of using a new nut and lockwasher. Repair was done a year ago and is still good.
5) See #1. Call the repair company or tech. Hopefully your repair is less than a year old. Not all repairs or techs are equal!
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
I purchased a GE dryer and washer for my mother in April 2011. In June I initiated service under the warranty. Because of the policy that states 3 services before replacement can be established I am 7...
i have been a appliance tech. for 30 years now and have loved ge's slogans they were
ge cares and i would add a question mark to that....they changed it to
ge brings good things to life and i would say that good thing was job security
Jul 26, 2011 | GE Dryers
I just bought a 35 w halogen bulb from lowes for my GE truetemp profile JKP56 built in oven. I just spoke to a GE rep who sells the bulbs and he said the bulb has no replacement numbers so I don't...
If the bulb you bought from Lowes is a 35 watt bulb and it screws in, then it will work just fine.
Appliance parts people love to sell you the "one" specific for your model because most of the time it is more profitable for them.
Good Luck!
Joey
Jun 11, 2011 | GE Profile JKP56 Electric Double Oven
I need the manuals for washer Model #WFW9500TW03 and dryer Model #WED9500TW3. We recentely purchased our new appliances from our local Lowe's store but the manuals had been removed and the store was...
Both these manuals are available at managemylife.com. Just type in the model numbers you provided under the "Manuals" link and you will find them in .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
May 27, 2010 | Whirlpool WFW9500TC Front Load Stacked...
My GE washer has a small cut on bottom door seal, is there a glue or seal that can be used to make repairs rather than purchasing a new door seal
Find a Epoxy glue that will hold up to the rubber or plastic that this is applied to for it may melt the rubber if not the correct type Two Parts Epoxys are good!
Jun 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Manual for a GE DECT handsfree phone
To get a copy for my GE 28213 I did a search at:http://www.home-electronics.net/ge/pc/home.asp
I put your model in the search and it came back with no results so perhaps it is not available in English. There is also a "contact us" tab at that site perhaps you can get help there.
Good Luck
Aug 22, 2008 | Uniden Cordless Phone
We bought a Maytag Washer Dec. 07. The machine started to squeak shortly after the purchase. I was hoping it will go away, but it is not. Each time I use the washer we can hear the squeak through the whole...
The brake pad is squeaking in the brake drum. Like when the brakes on your car get glazed. It's annoying, but it won't affect the operation. Call the store where you purchased it and set up service to have it repaired. If the tech they send doesn't have a brake tool, or seems clueless, have them send a different tech. Be sure they replace the parts - not just scuff up the pads and drum already in there - Maytag's buying!
Unfortunately, there's no guarantee this will permanently take care of the situation. I have noticed that doing larger loads actually helps condition the brake seating surfaces when the parts are new.
Mar 12, 2008 | Washing Machines
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
81 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
