Please don't forget to rate! Trouble Code Conditions: Possible Causes:
Trouble Code: P0871 (3.5L V6 VIN G Auto)
A/T O/D Pressure Switch Circuit Malfunction
Engine started; vehicle driven in a forward gear, and the PCM detected that the O/D Pressure Switch circuit indicated open or closed at the wrong time.
Trouble Code: P0700 (3.5L V6 VIN G Auto)
Automatic Transmission Control System Malfunction
Ignition on or engine started. The PCM received a message over the CCD Bus from the Transmission Control Module (TCM) that it had detected a problem and set a trouble code in memory.
