This is a high output piezo pickup but won't give line level signals expected by some inputs so I would guess you may be going into a line input. If so try a mic input (XLR) instead and see if that works.
A buzz on one string is not due to a pickup fault. It's rather a too low string height at the nut or a string slot that is either too wide or has too deep of an angle towards the tuner. It could however be that you had the pickup too close to the high E string creating excessive string pull.
Probably the ground wire is broken on this either at the jack or very near the end of th pickup stick. This acts like a condenser microphone and is fairly high impedance so any break in the ground will pickup hum. Using a high impedance guitar cable is necessary.
These pickups have a very high impedance so you must run into a high impedance input. Many amps expect low impedance guitar outputs and these piezo pickups just can't drive them.
We currently use an X2 wireless system which has over a 1.5 megohm input impedance which works well with these piezo pickups. Long guitar cables degrade the signal as well and running into a DI just won't work.
Try holding the pickup in the cavity in the position you want without the springs. Use a bit smaller than the mounting holes in the pickup to predrill the holes in the body through the pickup holes while you are holding the pickup in place. When you are ready to mount the pickup use a little hot glue on the ends of the springs to hold then in place over the mounting screws on the bottom side of the pickup. With the screws and springs in place on the pickup carefully screw the mounting screws into the predrilled holes in the cavity. Try using a pin vice to hold the drill bit or one of those small drills that you can operate with one hand( your second finger and thumb hold the slider and your index finger does the downward stroke). Here is a link to a really good site:http://www.stewmac.com/freeinfo.html
The piezo pickups for violins REQUIRE a high impedance input preamp.
The measured impedance of My wife's violin is on the order of 2 megohms.
It sounds like you are having cable connection problems. If you don't have a preamp right at the vilin, then use a VERY short high impedance instrument cable.
Most of the Focusrite mic preamps I looked at had input impedance around 5K ohms which is unsuitable for the piezo pickups.
Here we use an Autolycus pickup on an acoustical vilin and an X2 wireless system. The transmiter has a very high input impedance and the resulting system sounds like a violin.
Some amps themselves DO have a high input impedance, but many designed for guitars do not. Long cables, especially low impedance ones, load the piezo pickup with capacitance which clobbers the high frequency response.
Pickup height on electric guitars is an oft debated subject. It's more about personal preference, ..BUT there is a bit of science involved , and here is some real simple "String Theory" for electric guitars. Your pickups are magnets essentially, with little winds of copper wire - this is how a transducer (pickup) picks..up (hence PICKUP) the sound of the strings. Strings are steel , most brands have Steel wrap around a Nickle core, ..it is ALL attracted to magnetics. You've played with magnets before , right? What happens when you put a magnet close to metal? It...PULLS it , right? Now , here's the deal about THAT , for guitars. The closer you get a vibrating string to the pickups , the more signal the string will produce , BUT if you get TOO close, the pickup will start pulling on the string too much (remember..magnetics) and that will reduce the amount of sustain on a string(s), and may even hamper actual tuning depending how strong the pickups are. Of course there is the "Duh" factor - having your pickups so high that your strings actually rub them as you play , ...don't do THAT! Best advice: Keep the pickups about mid-way. Not high enough to cause any noticeable problems, but not too low to sink them below the pickup rings (the plastic rectangulars that surround the pickups.
looks like the pickup thread is damaged, it happens often... open the pickguard, remove pickup and repair thread flattening little bit pickup flange by small hammer thread will become usable again
I am a gitarist myself too and firstly let me tell you u have purchased an excellent guitar to begin with!! Now about the Neck\blues pickup.....If you say there is little sound this can be because of:- 1)Faulty bridge adjustment 2)There can be a problem also because of the neck of the guitar being a bit bent in or around the place where u have the pick-ups though the chances of that are rare.
If there is no sound then please contact your dealer to change the piece.... Have a great time playing
Hoping this helped.Any help regarding the above steps , feel free to ask them. See ya.
