Kenwood KAC-7202 Car Audio Amplifier Logo
Posted on May 08, 2011
Hooking up the amp i had the ground wire connected and was going to hook up the power wire and it hit the case of the amp know the amp turns on but there is no sound from the speakers other amps work on the same wiring and the subs work as well
matthew walsh
Level 1:
Habit-Forming:
New Friend:
  • Contributor 70 Answers
  • Posted on May 09, 2011
matthew walsh
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
70
Questions
Helped
20298
Points
81
Sadly, your amps' output MOSFETS are more than likely toast.
your amp was grounded, and you touched the amp chassis with the power line.
electricity will follow any path available to find ground. in your case, the output mosfets became your main ground-path since they are directly connected to the amps chassis (heat sink) and internally you had grounded the amp so power would flow full force through the output transistors in the serach for a ground.
open up your amp and smell the row of MOSFET transistors. you'll probably even be able to see some burnt transistor legs.
repair or replace.
1helpful
Rear harness was bad they replaced with trailer harness and trying to fig out what yellow brown light green an dark green are on frame of truck it hooked in to so i can fix i un hooked not knowing what had...
Your description, I take it, is a problem with the wiring harness going from the driver's compartment to the rear lights. If that is the case, the normal color code for GM is brown for tail lights, dark green for the right stop & turn, yellow for the left stop & turn and light green for the backup lights. Any black wires should be grounded. The white wire in the trailer harness is for a ground when used on a trailer. It sounds like you have the green and yellow T&S wires shorted together somewhere! Some of the later vehicles use separate stop and turn bulbs... these would have a separate wire for the stop lights only, but I don't think your truck is new enough for that. Good luck!
2helpful
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
2helpful
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Power is hooked up. Ground is connected. Both subs are connected. The triangle light is red, and there is now sound. All wires are hooked correctly...
on most amp red isnt good that means it in protection mode try turning your setting on the amp down all the way and turn the volume down tell you can get sound out of them then turn up the volume to were you would to them most and set the to what sounds the best but make sure the light doesnt dim down when the base hits
2helpful
I have a pioneer gm 2200, i dont know how to wire it up to my car, could you help thanks
you should have 4 or 3 wires... cd turn on wire, ground wire, power wire, and last audio input and output wire... to hook the power wire up you would have to lead it going to the power source and make a hole or find one to travel it to the engine from inside the car, then bolt it the the car battery terminal. the ground wire you would have to bolt it to the body of the car from inside the trunk or where ever you have the amp, as long as it is connected to somthing metal! the cd turn on wire you would have to travel it to your (after market cd player or stock) to behind it, into the connecter which should be 16 or 12 and hook it in one of the wire holes! this also goes for the audio input and output wires, connect one end to amp then other behind the cd player! make sure to leave anough slack to b able to connect to amp! hope this has been helpful :)
I have a 1200 watt sony xplod amp hooked up to a 15" SBL Gorilla sub. The bass hit for a while and then started to cut off. Now it wont work unless i touch the remote wire to the power wire, and even then...
this kind of problems usually happen when the amp is not getting enough current to power up the
 amp. the moment a loud low frequency hits the amp it fails. cud be ur power unit not giving enough power to the amp or u have a loose connection somewhere on ur power line. besides 8gauge is a bit small. try using about 4gauge. should have good ground too. they draw large current so ur battery should be in top condition as well.
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
My kenwood amp wont turn on
What kind of "Clips" did you put on? They may be causing too much resistance and preventing the amp from getting the current it needs. Double-check with a voltmeter that you are getting at least 12 volts at the amp power connections and make sure your ground lead is as short as possible and connected to solid metal of the vehicle's chassis.
Amp
Make sure the amplifier is turning on. Remember ther is three wires that power the amp Battery constant, Ground which in a fiberglass boat run ground to battery not motor, Plus make sure the remote wire is hooked to power, generally it is switched power. But if the amp is not turning on temporarily hook remote and power together to battery and see if the amplifier turs on. Second be sure you have a good set of RCA cables hooking the radio to the amp. And finally check and make sure the gain is turned up on the amplifier.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
