Cannot get google account on my defy says cant find reliable connection to server. what can i do to make it work.
and it says that: "this could be a temporary problem or your phone may not be...
If you haven't configured your phone to access the internet yet, and you want to do it through your network carrier's data plan, bear in mind their APN settings. Contact they, in case you don't know such data. Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in a 'Name' for it, and, at least, your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, prior you started making these changes.
On the other hand, if you want to access the internet through wifi (e.g. your home's wireless network, or an internet cafe), go to 'Menu > Settings > Wireless & networks' and tick the 'Wi-Fi' checkbox, in order to turn your phone's wifi radio on. Then, tap 'Wi-Fi settings', and, if the network you want to connect your phone to doesn't appear on the available networks list (e.g. a hidden network), tap 'Add Wi-Fi' network' and fill in 'Network SSID', select the security method, and fill in the password, if needed. When you finish, tap 'Save'. You can also specify how your phone will use its wifi radio. Tap 'Menu > Advanced > 'Wi-Fi sleep policy'. Again, press the back button as many times as required to return to the home screen.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards,
Carlos
