Question about JVC KD-SX770 CD Player
JVC KD-G386 CLOCK SET PROBLEM - JVC KD-SX770 CD Player
Posted by hrgoldfinger on
5 Related Answers
Anonymous
SOURCE: cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Posted on Jan 18, 2009
Anonymous
  • 3 Answers
SOURCE: clock set
To set the clock on the JVC KD-G200 see here.
http://www.fixya.com/support/p187738-jvc_kd_g200_cd_player/manual-17158/page-9
Posted on May 20, 2008
Anonymous
SOURCE: Clock
Press and hold the 'select' button until a menu displays. Use track forward to cycle through the menu and the volume knob to cycle through options of each menu. You will find 'Clock H' and 'Clock M'...set accordingly.
Posted on Sep 25, 2008
Anonymous
SOURCE: clock set
To set the time press and hold the select button in the centre of the volume dial until the word demo appears on the screen. From here you can change the time by pressing the next track >>I button to select clock h. Use the use the volume dial to select the hour. Use the next track button >>I to select clock m and use volume dial to set the minute. This same procedure can be used to change the dimmer on/off, demo on/off and the amp gain. Have a play around. Hope thjis helped.
Posted on Feb 21, 2009
Anonymous
SOURCE: how to set clock jvc kd-g200
hold in select button for over 2 seconds it will change from tone settings to another menu then rotate knob CW to clock H or M press in and use knob to set.
Posted on May 05, 2009
Replaced the battery in the car but now unit seems dead although power to inline fuse is OK. KD G386/385 Has it got an internal fuse ?
It might be a good idea to check all of the fuses in the car. The radio requires two power sources in order to work properly.
Aug 22, 2011 | JVC KD-G340 Car CD/ MP3 Player
Manual for jvc kdg385
www.jvc.owner-manuals.com/JVC-manuals.html
or
www.manualslib.com > ... > JVC Manuals > Car Receiver > KD-G386
Aug 22, 2011 | JVC Car Audio & Video
I need to know how to set the clock on my JVC 180w KD S580 radio
Press and hold sel and press and hold disp. Use Vol+ and - to set the hour. Then press fast forward to get to minutes.
Thanks.
Jul 02, 2009 | JVC KD-S580 CD Player
Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Jun 10, 2009 | JVC KD-G230 CD Player
How to set time on cd player
How do i set the time on my JVC kd g386 car stereo
Sep 27, 2008 | Car Audio & Video
Have just installed (per instructions) a jvc car cd KD-G386/KD-G385 receiver in my caravan, nothing seems to operate, have reset it. and press "display"button-clock comes on for couple of seconds...
Hi colinelva.
I can probably help you but I need more info.
Lets start with the vehicle, What year ,? What specific model?, What type of head unit came out? Was it factory?
Did you use a wiring adapter, or just cut the plug off and hardwire it?. If so give me the color code of all the wires that you used in the dash. are their any left over but not hooked up? How many speakers? All Factory?
I don't need any info about the JVC Head unit.
Lets start with that, and we will take it from there.
Regards, Paul
Jun 13, 2008 | JVC Car Audio & Video
Car clock setting
For the JVC KD-G200 look here for instructions on how to set the clock...
Nov 25, 2007 | JVC KD-G200 CD Player
Clock set
Nov 04, 2007 | JVC KD-G200 CD Player
Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Mar 17, 2007 | JVC KD-G420 CD Player
JVC KD-SX770 CD Player Logo
292 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
