Nintendo Wii Console Logo
Posted on May 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant put the wi fi on my wii - Nintendo Wii Console
Anonymous
Level 2:
Scholar:
  • Expert 72 Answers
  • Posted on May 08, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
72
Questions
Helped
13783
Points
169
Wireless Connection: Step 1: Turn on Wii
Step 2: Select the Wii button on the left side of main menu.
Step 3: Select "Wii Settings"
Step 4: Scroll until you see "Internet" and select it.
Step 5: Select "Connection Settings"
Step 6: Search for an open connection by "Connection 3:None button"
Step 7: Select "Wireless Connection" and search for access point.
Step 8: Choose the access point desired from the list and save the settings.
Step 9: Test your connection. If successful you are connected to the internet if not go back and check your connection settings.
2answers
Do you have list of current Nintendo wi-fi connection-compatible software?
not sure if this link will help you outHow to get around the Wii Error Code 20110. Nintendo Wi-Fi Connection service for this software has been discontinued. Visit support.nintendo.com for a list of current Nintendo Wi-Fi Connection-compatible software. ... Anyway, it is still possible to play Mario Kart Wii or Super Smash Bros. Brawl online.
How to get around the Wii Error Code 20110 - St?phane Caron
https://scaron.info/blog/wii-error-code-20110.html... current Nintendo wi fi connection compatible software Google Search
Error 102-2931 on wiiu
  • Power cycle your home network.
  • If your wireless router or access point is unresponsive, power cycling these devices may resolve your connection issue.
  • Ensure you are using the correct password for your Wi-Fi network.
  • If your wireless router or access point is secured with a security key or password, review this password to ensure you have entered it correctly in the Wii U.
  • Create a new connection on your Wii U.
  • Create a new connection on your Wii U. This will ensure you are connecting to the correct Wi-Fi network and the Wi-Fi network is currently visible to your Wii U.
  • Check for wireless interference.
  • Wireless interference can result in a weakened connection between your Wii U and your wireless router or access point. Review your Wi-Fi network's setup to ensure an optimal wireless environment.
    Still Not Resolved:
    • If the issue persists, please contact at 1-800-255-3700. Specially trained representatives will be available to assist you, 6:00am - 7:00pm (PST), seven days a week.
Cant get on line with wire less
You have to go into settings and have the WII detect the WI-Fi router and then enter the passcode for the WII to login to the router.
Any more questions let me know.
I cant get a internet on my console wii
You have 2 wireless options. Either you use the built in wi-fi of the Wii by selecting the internet menu option, locating your wireless ID and entering your Security Key. Or use a USB wireless device to receive your wireless connection. If you need more help, give more details!
I dont know how to connect my internet to my wii
the wii has a built in wi-fi reciever so you HAVE to have wi-fi if you dont buy a wireless router hook it up to your computer you need to have high speed internet for this then once your wi-fi is set up go to wii options internet connection then click search for connection if you have it set up right it will show your connection name then you click on it and it will retrieve the signal from your connection and you can go online from your wii.
3answers
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Wii wi-fi
You need to go through the wireless setup on the Wii settings page to ensure that the security settings are coorrect. You may also need to check the placement of the Wii because if you keep it in a TV cabinet it might not be able to get the signal.
Wii won't connect to Wi-Fi network.
Please note that your wii console has a lower internet signal (less bars) and you must get a little closer to connect. Or your wii must have another problem i cant solve.
I have brought the nintendo/wi-fi usb connector. The computer/wii can see one another but i cant get internet access
you have to select a game and configure a connection through the game. it is like a ds you cant configure the connection on the homescreen you have to go into a game go to setting and find the wi fi connection tab then they will find each others signals and you will connect.
2answers
How do i set up the wii for wii-fi?
the way to set up wi-fi is to get a wireless router its not really wireless it just has antennas then set up your wi-fi on your wii or have a wired modem and just buy the wireless USB it really is wireless then set up your wi-fi on your wii.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
