TRY OPENING AND INSPECTING ALL AREAS WHERE THE PAPER GOES. USE A TORCH OR BRIGHT LIGHT TO CHECK IF THERE ANY BITS OF PAPER. ALSO CHECK IF ANY BITS MISSING FROM THE JAMBED SHEET OF PAPER. LOOK FOR A SMALL PIECE OF PAPER. AROUND THE ROLLERS OR PAPER MOVEMENT AREA. .ALSO IF PRINT HEAD IS ON LEFT SIDE GENTLY MOVE IT TO THE CENTRE WITHOUT TOUCHING ANYTHING, AND CHECK FOR ANY PAPER BITS BEHIND THE PRINT HEAD..
TO DO THIS YOU MUST REMOVE THE PAPER JAM COVER AT REAR OF MACHINE, LIFT UP THE WHOLE SCANNER COVER AND INSPECT. WHEN COMPLETE REPLACE THE REAR COVER AND CLOSE THE MACHINE. THEN RETRY.
HOPE THIS HELPS BARRY UBON.
