"F20"
is a water inlet problem. This indicates you have insufficient water
supply for the washer. Whirlpool is the manufacturer of your washer and
they recommend that you unplug the washer and check the following:
1. Check water faucets to ensure they are completely turned on.
2.
Check the inlet hose screens where they connect to the washer. The
screens can clog with sediment over time and require cleaning. This can
be a problem if you live in an area with well water and/or hard water.
3. Ensure the inlet hoses are in good shape and are not kinked.
If
you check all the common sense items first and the problem still
persists, you need to check the water inlet valve. To access, you will
need to remove the top panel of the washer by removing the three screws
that hold it in place. Once the screws are removed, the panel slides
back, then off. The water inlet valve is located in the left-rear of
the washer just prior to the dispenser. Double the electrical
connectors to make sure they are not corroded and double check the hoses
that run from the inlet valve to ensure they are not kinked. A
resistance check of the water inlet solenoids (with the connectors
removed) should read about 800 ohms. If the solenoid readings are
abnormal, replace the valve.
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
If you have ever experienced the problem where you washer continually
fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as ?siphoning?. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
I hope these tips are informative and will help prevent some of the more
common washer drain problems that can easily be mistaken for a more
serious problem. You can save yourself a service call, just by double checking your installation.
Hope helps (remember to rate this answer).
SOURCE: Kenmore Elite Front Load Washer
ok heres what u do take the bottom toe panel off the machine be sure to unplug it first. either in the panel or on the sides of the inside of the washer will be a tech sheet look up the error code and let us know what it is i cant remember off the top of my head what 33 is
SOURCE: F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
SOURCE: front load kenmore washer giving error f20 messsage.
take the kick panel off and find the tech sheet. i believe you have3 either a bad pressure switch or something stuck in your pump. let me know how it goes
