Question about Roundup "" Weed & Grass Killer
I have Roundup with no instrutions. 1 litre, concentrate. How much into a gallon container do I use? thank you
Posted by nbmerrifield on
Peter Freese
    New Friend:
  • 56 Answers
For general use I use 3 ounces of herbicide per gallon of water. For best results spray on a calm warm morning.
Posted on May 07, 2011
What is the ratio of water for roundup?
what does the size of the round up container say ?
it depends on what you want to get rid of. Weedy plants, vines , broad leaf plants need more round up guess 80 ml per litre.
Grass 20 - 35 ml per litre
However it really depends on the round up as some round up is a higher concentration and then you need less roundup to water
May 07, 2016 | Garden
I cant read the instructions
If it is extended control Round-up, it should be ready to use! Make sure not to use it close to any trees or bushes, as it can damage or kill them! (hint: add a squirt of dish soap into the container to aid in coverage on the leaves) If its concentrate, mix it at 6 fluid oz. per Gallon. Most "ready to use" containers come with a sprayer, as concentrates do not. Happy spraying!
Sep 24, 2011 | Roundup MS5700010 1GAL ROUNDUP CONTROL 1...
I have a bottle of concentrated "Roundup", but
Roundup concentrate is normally mixed at the rate of 1 to 50 or 2%. This should kill most weeds and you can treat hard to kill weeds with a second application. 2% works out at about 3 fluid ounces per gallon. For an imperial or UK gallon you would need 90mL or 75 mL in a US gallon. You will probably find a bottle or can around the house which has this capacity and cut the top off it to use as a measure.
Jul 18, 2011 | Roundup "" Weed & Grass Killer
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
How much roundup concerntrated herbicide mm per litre to kill grasses and simple garden weeds
for roundup weed & grass killer concentrate plus you would use 3 oz per gallon or 29.57 cm^3 per litre
Dec 28, 2010 | Roundup "" Weed & Grass Killer
How much Roundup do you mix in one gallon of water?
If you have the concentrate (label reads Concentrate Plus), the amount of Roundup will depend on the plants you want to kill. Use 6 fl oz (12 tablespoons) for 1 gallon for most plants. If you have seedlings or easy to kill weeds, use 3 fl oz (6 tablespoons) per gallon.
The Super Concentrate may have a different rate. The labels are usually on the manufacturer's web site as PDFs.
I hope this helps.
Jul 05, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 25, 2010 | Roundup ScottsRoundUp 0394560 PT...
HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
May 22, 2009 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
254 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
