On the left side menu click on Bathroom Fixtures; click on Toilets, click on next under the questions to move to question 18, How Do I Install the 84995 Flapper?
RAM refers to Random Access Memory. Slot could be more or less a generic term for what ever feature your particular lap top has. It's likely for additional external RAM or something like that, it should tell you in your owners manual.
WELL FIRST IF THEY ARE DUAL VOICE COILS, IF SO,TO GET 2 OHMS JUS THOOK THEM UP TO ONE OF THE TWO TERMINALS, IF YOU WANT 4 OHMS HOOK YOUR POWER LEAD TO ONE TERMINAL THEN ABOUT THREE FEET OF WIRE COMING FROM YOUR LEAD TO THE O9THER TERMINAL, IF YOU WANT 8 OHMSHOOK YOUR POWER LEAD TO + ON ONE SIDE THEN THE NEGITIVE LEAD TO THE - ON THE OTHER SIDE, THEN VISE VERSA. BUT IF I WHERE YOU MAKE THEM 4 OHMS
you will get more power at lower ohms, the lower the ohms the less resistance it will have against the amplifier
heres a small definition if it helps
The ohm is defined as the electric resistance between two points of a conductor when a constant potential difference of 1 volt, applied to these points, produces in the conductor a current of 1 ampere, the conductor not being the seat of any electromotive force.[
