Xerox 3030 (engineering printer)
NVN Fault (call for assistance) is showing on screen.
We had a lightning storm yesterday.
I don't want to pay 300 bucks for a service call for something
we've called about before and seemingly took 2 mins. to fix.
Is this way over my head? Or a quick fix?
Thanks
Posted by crig on
  • fixitforgerr Mar 09, 2009
    num fault[call for assistance]
5 Related Answers
Rick Kasper
  • 2072 Answers
SOURCE: xerox 8550 showing error code
  • Check that all system grounds are secured.
  • Check or reseat all connections to the Electronics Module.
  • Check the condition of all harnesses.
  • If the problem persists, follow the procedure below.
  • Check ground integrity for the printer.
    Does the error persist?
    Go to Step 2.
    Complete.
    Reseat all system interconnections and check that the cables are properly dressed.
    Go to Step 3.
    Complete.
    Reset NVRAM.
    Locate the error code below.
    Complete.
    For errors 11, 001.47 and 11,017.45
    Replace the Tray Lift Motor.
    Replace the Electronics Module ( REP 5.0.5).
    Complete.
    For errors 11,002.48 and 11, 016.44
    Check the Option Tray connection.
    Replace the optional tray.
    Complete.
    For errors 11,003.49 and 11,0014.42
    Replace the I/O Board ( REP 5.0.13)
    Complete.
    For errors 11,004.41 and 11,013.41
    Replace the I/O Board ( REP 5.0.13).
    Replace the Control Panel ( REP 1.0.9).
    Complete.
    For errors 11,006.43 and 11,015.43
    Replace the Printhead ( REP 2.0.2).
    Complete.
    For error 11,009.46
    Complete.
    For all other 11,000.4x errors:
    Complete.
Posted on Apr 14, 2008
Anonymous
SOURCE: XEROX DOCUCOLOR 12
If you open the front door of the DC1250 and pull out the conveyor unit, you will see the heater unit on your right hand side. We need you to remove the heater cover (fastened by two screws). Once the heater cover is opened, you will see a black long strip on your left hand side whereby you will notice oil on it. Next you remove the fuser web (on the right hand underside of the heater unit) whereby it will reveal the Upper heater roller and Lower pressure roller. Please check if you see any oil stains on the Upper fuser roller. If there is, it means the oil pump, oil pipe etc are working well (i.e oil is supplied to the Upper roller).
Next we need you to check if there are any scratch marks on the Upper Heater Roller. We need you to recall if you have had encounter or incidences of paper jam at the heater unit whereby you pulled out the paper to clear the jam. We are concerned that the upper roller may be scratched. From the print out results, there is a fusing problem with the copier, which could be a result of the fuser nip clutch and also the upper fuser roller.
Posted on Aug 21, 2008
Rick Kasper
  • 2072 Answers
SOURCE: Xerox 2424 Print head not parked
A copule of things cause that.
Here are the main 2.
On the left frams looking from the front, with the covers off, there is a 1 inch square stainless steel print head block that is located about 2/3s of the way back , near the bottom of the frame. Look at that and see if there is ink built up in that block , also under and around the block. If so remove the spring holder thats over the block and take channel lock pliers and remove that block. It may be very stiff. To clean soak it in hot water to soften the ink and clean that block, the shaft and all the remaining ink under the block you can remove. Once you return the machine to working order, take a level and out in on the glass. Make sure it is LEVEL front to back and side to side.
Number 2 is the print heasd wiper is stuck to the print head. That requires removing the scanner/document feed assembly, the side covers, the upper rear cover and the ink loader assembly,( where you put the ink sticks). Once you remove that you have access to the print hear drum area. If needed carefully pry the wiper from the print head and return to service. That blade will stick if the machine is not properly shut down.
I strongly suspect the machine is not level and when you ran the cleaning mode, it sucks all the ink out of the print head. Most likley while that ink was dropping into the tray, it ran out the back of the tray.
Posted on Sep 10, 2008
Rick Kasper
  • 2072 Answers
SOURCE: Xerox Workcentre 24. 20 months
That is a software processing error.
Do you have it set up as a printer? If so, try removing the print cable and power it on that way.
If that doesn't work, you need to have the firmware reloaded. That can only be done from a laptop with Xerox software on it.
Posted on Oct 03, 2008
mikeppi
  • 7 Answers
SOURCE: Epson 9800 Service Call Error 001002D
cleaning unit end of life
Posted on Dec 20, 2008
Xerox 3030 (engineering copier)-- "Toner Fault. Call for assistance" is on the little display screen. Can I easily fix this myself?
I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
Dec 05, 2014 | Xerox Office Equipment & Supplies
Xerox 3050 fuser replacement
Assuming you are talking about the Xerox 3030/3050 wide format printer, you don't replace the fuser, only the individual components eg. fuser roll
May 11, 2012 | Xerox Office Equipment & Supplies
Have a Xerox 4118P WorkCentre that I just received yesterday. Copies were perfect yesterday, today they are blank. Very low copy volumn thus far. What could cause it to suddenly print blanks?
Pick up the phone and call the company that sent you that printer and have them send you another printer or someone who can fix the printer.
That's what you warranty is for.
Better still, return the defective printer to Xerox and then purchase a Lexmark printer. :)
Don
Oct 28, 2010 | Xerox WorkCentre 4118P All-In-One Laser...
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
My scanner stopped working yesterday. Tried everything and no luck. Its an MP830 and the printer works fine.
Did you have a storm or lightning? Try unplugging the power cable from the left rear of the machine (not the wall). I have had to do this on several occassions after storms. Good Luck!
Jan 20, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer will not print after lightning storm
Hi chk u r parllport working /not?
if u have drivers cd ,delete the printr &restart u r computr,see u r computr is detected the prntr /not ?if detect install drvs &chk
tell me ple.
Aug 12, 2008 | Epson LX-300 Matrix Printer
168 people viewed this question
Ekse
Marvin
Marvin
