Thank
you for posting your question here on Fixya.com. Removing
the impeller requires you lock the shaft as you turn the impeller off
counter-clockwise. You will also need to check for an impeller screw in the
center of the impeller inlet. If a screw is present they are usually left hand
thread. Back out the screw first, then proceed to remove the impeller. To
lock the impeller you will have to remove the motor end cover or a cap covering
the shaft end depending on which version your particular motor has. Look at the
end opposite the pump and imagine a shaft from one end to the other right in
the center. Once
you remove the cover you will see a slot for a screwdriver, a flat for a
wrench, a hex hole for a hex key or some combination of these. Lock the shaft
and spin off the impeller. Some are so tight you will end up breaking them in
the process. Simply replace it and the seal. Be sure the motor shaft is in good
enough condition to allow the new seal to work properly. If too much shaft
material has rotted away the new seal will leak soon after it is installed; you
would need a new motor at that point. If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is
appreciated once your problem is solved! John
Hi John,
I'm having one heck of a time trying to remove the impeller on our Hayward SP-2610X15 pump in order to replace the seal assembly.
There are absolutely no screws to remove the cover, and I can't seem to locate any "cap" to pry off either. Any additional information from you would be greatly appreciated.
Tks!
Can you email a couple of pictures of the end of the motor? If so, please contact me thru www.arrowmotor.net or email them directly to [email protected].
