Question about Vivitar ViviCam X327 Digital Camera
Trying to set date/time for the first [ what is the wrench button?]
Posted by anthonyst35 on
Chris Ford
    Scholar:
  • 147 Answers
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
Posted on May 07, 2011
  • Chris Ford May 07, 2011
How to set the date and time on a fijifilmfinepixxp50 camera
Press the MENU/OK button to bring up the menu. If necessary press cursor-left and cursor-down to select the wrench-SET icon and press cursor-right. Select the "Date/Time" command.
Aug 25, 2012 | Cameras
How to set date and time on a finepix z110
Press the MENU/OK button to bring up the menu. Press cursor-left then select the wrench-SET icon. Press cursor-right then select the "DATE/TIME" command.
Full details are on pages 15 and 72 of the manual.
Aug 01, 2012 | Cameras
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
J4680 help set date and time
Press the Setup button. (Far right button with a picture of a wrench on it.)
Use the Arrow buttons to go to Basic Settings. Press OK.
Use the Arrows to go to Date. Press OK. Use the number pad to set the date. Press OK.
Do the same thing to set the Time.
Here is a page that gives it also from HP. Scroll down to Step 6.
J4680 Setup
Here are links to your printer's manuals for future reference.
J4680 manuals
Thanks for using Fixya.
Mar 23, 2011 | HP J4680 Office Jet All-In-One Printer
I dont know how to set the time and date
This is for a Nikon Cool Pix Model - Turn your camera on - press the menu button - down arrow to the little wrench picture (select left arrow to get to icons on left of screen) then click down to wrench .. date should be one of your choices click down to date - clik okay or right arrow .. date should appear right arrow and camera will walk you through setting date.
Mar 15, 2011 | Cameras
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
Feb 28, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
How to change the date setting on my camera
1. Press the Menu button.
2. Press the Right/Left buttons to select the wrench.
4. Press the Menu button.
5. Press the Right/Left buttons to press and highlight the various components. Press Up/Down to set date, time, and format.
6. Press the Menu button to confirm, save, and exit.
Jan 27, 2010 | Vivitar ViviCam X327 Digital Camera
Want to know can I set date and time
Yes. With the camera turned on, press the Menu button, and then scroll left or right until you are on the settings menu (hammer and wrench at the top). Scroll down until you are on the date/time setting option, and press the SET button. Use the left/right buttons to select month, day, year, hour, minute, and use the up/down buttons to change settings. Press SET to save, then press Menu to exit.
Apr 24, 2009 | Canon Cameras
Date and time setting
The date/time is in Setup 1 (the wrench icon in the middle). Scroll down to Date & Time, then click the right side of the wheel button to set the date and time.
I hope this helps! If so, please rate the solution.
Regards,
Char1ieJ
Dec 16, 2008 | Samsung S630 Digital Camera
Vivitar ViviCam X327 Digital Camera Logo
328 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Barbat Nae
Barbat Nae
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
