Question about Cameras
Picture once put into compoto r shows it is blurry.
Posted by hippie4ever1 on
David Shaub
    President:
  • 2,976 Answers
If your pictures show up blurry on the computer, either they are not focused or you need to switch your camera to a larger format. When you look at a picture on a 2X2 screen, what looks clear will lose purity when you blow it up. If your pictures are 500K they will only look good when they are small. If you set the camera for 1.5MB, they will look good when they are enlarged. Compare the pictures taken by a cell phone with those taken with a 10MP camera. You will see the difference right away.
Posted on May 07, 2011
Pictures come out blurry if any movement
The most likely culprit is a slow shutter speed. If the subject moves while the picture is being taken, you'll see it blur. If non-moving objects show up sharp while the moving objects are blurred, then this is definitely it.
Another possibility is camera movement. Try putting the camera on a tripod or a table or other steady support, then use the self-timer to take a picture. If everything in the picture is blurry, then this is probably the reason.
The third possibility is that the camera isn't focused on the subject. Try taking a picture of the subject when it isn't moving and see what happens.
Mar 16, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
Is there any way I can clear up a blurry picture on this camera once the pic is already taken?
On TV shows, they can take a blurry picture and enhance it to crystal clarity. In real life, however, those kinds of miracles aren't possible. In a photo editing program like Photoshop Elements, you can bring up the sharpness a little but you eventually reach a point where the picture no longer looks like a normal picture. The slogan is "garbage in...garbage out"...meaning you can only do so much to what you have to work with.
Dec 07, 2010 | Panasonic Lumix DMC-LS75 Digital Camera
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
The screen shows a blurry picture. When I try to
Hello, you could try putting the setting on Macro and that is the little flower
on the bottom along with the other buttons. then you'll have a nice
clear picture, just don't hold it tooo close to the item you are taking
a picture of.
Kat
[email protected]
Apr 26, 2009 | Olympus FE-280 Digital Camera
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
My kodak 10.3 megapixel md1063 is showing very blurry and when you take a picture they are all blurry also
Auto focus not working - Under warranty? One year from date of purchase. If not, take it to your Authorized Service Center. I know of one in Florida, I don't know where you are located
Apr 13, 2009 | Cameras
Pictures blurry
typically if camera is not set to autofocus, pictures come out blurry. make sure to put autofocus on. when u put autofocus on, u usually need to press button twice to take picture.( 1st to set autofucus, 2nd time to take picture) hope this helps ur issue.
Aug 14, 2008 | Cameras
Pictures are blurry
Maybe you have the camera set to a slow shutter speed. Try putting it on Program mode.
Oct 18, 2007 | Photography
Cameras Logo
Top Cameras Experts
ADMIN Canada
ADMIN Canada
Harrie
Are you a Camera Expert? Answer questions, earn points and help others
