SOURCE: ilo TV, universal remote
If you do a manual search of the remote, That means that the remote trys every code that is programmed into the remote and that there are none avail to use. Sorry. I think newer DTV remotes have the codes for this make of TV set. You should try calling DTV or going online ay DTV and ask. good Luck
SOURCE: trutech t2000-d remote control codes
I have the same problem as well. I bought 3 different remotes and not one will work with the tv. Although all 3 gave Trutech codes (1116, 1504, and 1713).
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
SOURCE: Who is the manufacturer
This television is manufactured by or distributed by.
Starlight Randix Corporation Inc
Minneapolis, MN, United States
