Brother SE350 Mechanical Sewing Machine Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4 times. My needle has broken 2 times in the last day and now now the bobbin is the issue.
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on May 07, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
31880
Points
167
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Two threads coming from bobbin?
try adjusting the top thread tension-one number or letter less, then
sew on a piece of the scrap fabric if you have any. to see if that helps
make sure the bobbin is turned the right way in the bobbin case, I
know this may sound crazy but it can hinder the sewing, I was sewing
a skirt the other night & I turned the bobbin the wrong way & inserted
the bobbin into the bobbin case & it didn't work good,, I took the bobbin
out of the bobbin case & had multiple threads. so I had to clean the mess up & turn the bobbin the opposite way & the machine worked
just fine
The bobbin thread is loops on top of the fabric even when the top thread is loosened to 2
if you've taking the machine in 4 times to be fixed,,sounds like you need a different sewing machine repair shop.
have you tried changing needles?
have you tried rethread the top & bobbin thread
is it possible the bobbin thread in not correctly inserted in the bobbin case?
try a top thread tension of 5 & see what happens?
I can't seem to find the correct bobbin tension for any projects.
Hello
What did you do differently to gather? Did you change the upper or bobbin tension? If you changed the upper tension, set it back to 4. If you changed the bobbin tension (don't!), set the upper tension to 4 and fiddle with the bobbin tension screw (1/8 of a turn at a time, no more!) until you've got balanced tensions again.
Cure is usually take ALL the thread off of/out of the machine, give it a good cleaning (vacuum and brush only, no compressed air), oil if it is required, a new needle right way around, and then carefully rethread, following each step in the manual, and making sure you thread the top with the presser foot raised (which opens the upper tension and allows the thread to enter it.) Don't forget to put the presser foot down to sew, and hold on to the thread ends for the first couple of stitches in a seam.
Where do i fix the tension at? i understand there is a top and bottom but i just dont understand. The thread keeps getting bunched up. It sews good for a bit then it just bunches up and i dont know what...
why dont you visit this website and read up some of the general info on sewing machines, should help you get started.
http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm
Usually you should only need to adjust the top tension a little bit for different fabrics but generally it should be fine on 5. Bottom tension is set by a little screw on the bobbin case (if yours is a removable front loading type) or sometimes a little dial if fixed horizontal bobbin case design. If machine has been set up correctly from new then bottom tension should not need to be touched at all.
It sounds more like your machine is not threaded properly, causing the thread bunching up to occur. If you don't have a manual you may find a threading diagram at www.sewusa.com or www.singerco.com, the Singer website has instruction manuals for download free for many models.
It sounds like you may be a beginner sewer, in which case, I highly recommend taking a few classes to learn how to best utilise your machine and save lots of frustration too.
Jul 07, 2011 • Singer 1507
6helpful
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
2helpful
The stitch on the bottom of the material is very loose and is bunching and looks terrible, the top thread keeps skipping and breaking, Ive fiddled with the tension and still having problems
Let me give you a general lesson on adjusting tension that will work for any machine. I suggest you thread the top of the machine with a different color thread than the bottom so that it's easier to see what adjustments you need to make.
Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
3helpful
2answers
The thread at the bottom of the matterial is loose.. I'm guessing it is the bobbin tension.. how do I adjust?
Actually, loose thread on the bottom is often because of a problem with TOP tension. So let me give you a general lesson on adjusting tension that works for any machine. I suggest you thread the top of the machine with a different color of thread than the bobbin so it's easy to see what's going on with the the two different areas.
2helpful
2answers
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Kenmore Model 385.16231300
I discovered the same problem. What I figured out (after having the machine "repaired" several times) is that it seems as if the bobbin type may be the suspect. I started looking closely and it seems as if I have 2 different types of bobbins. So, I tried both types. Since I don't know the bobbin number(s), you will have to put up with my description .... the bobbin that is flat, top & bottom, seems to bunch up. The bobbin "bounces" when I sew. The bobbins that are rounded on the top and bottom don't seem to "bounce" and it doesn't bunch up the lower thread. Now, I have read my manual front to back and it does not say what bobbin type or number to use. So, if anyone knows, it would be a great help. I am assuming the correct bobbin is the "class 66" bobbin. Does anyone know for sure?
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
