Question about GE 29888GE1 Digital Answering Machine
How do i erase messages - GE 29888GE1 Digital Answering Machine
Posted by artriley on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
To erase a message while playing, press the ON/OFF ERASE button. To delete all old message, while not playing or recording a message, press and hold the ON/OFF ERASE button until "MESSAGES ERASED" appears.
You can download a manual at
http://www.home-electronics.net/USER-GUIDES/29888_DOM_EN_AN_IB.pdf
Posted on Aug 08, 2011
How do i delete messages?
OMG ask once and wait
Jun 13, 2018 | Cell Phones
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
heard.
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
messages".
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
To erase a message while it is playing, press the ON/OFF ERASE button. The
answering system announces, "Message Erased" to confirm the message has been
erased.
To Erase All Messages: When the answering system isn't playing or recording messages, press and hold
the ERASE button until you hear the "Messages Erased" announcement. Release the
button after the announcement. This feature allows you to erase all old messages
but not new messages. If you do not have any messages, the answering system
announces, "Zero Messages."
User Manual: http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
May 06, 2011 | GE 29875GE Digital Answering Machine
The recorder dosent errs why
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Nov 16, 2010 | Sony ICD-B7 Digital Voice Recorder
Need to delete old voice message, can someone help
Erasing Messages
The unit will announce the remaining recording time after playback, if it is less than
5 minutes. New messages cannot be recorded when:
— “Memory full” is heard.
— “ ” is displayed on the base unit.
— ANSWER ON indicator flashes rapidly (only when the Answering System is on).
Erase some, or all, of the messages in a mailbox. We recommend you erase unnecessary messages after each playback.
Erasing a specific message
Press [ERASE] while the message you want to erase is being played.
• A short beep will sound and the unit will continue to play the next message.
Press [ ][4] while the message you want to erase is being played.
Erasing all messages in the mailbox
1. Press the soft key ( ).
2. Press the soft key ( , or ).
• If Mailbox 2 or 3 has a password, enter it (p. 51).
3. Press [ ][5] to erase all messages in the mailbox.
• A long beep will sound and “Mailbox (No.)” and “No messages” will be heard.
• To end remote operation, press [OFF].
I hope you rate this solution. Thank you and goodluck!
Aug 05, 2009 | Panasonic KX TG5100M Cordless Phone
Full memory
Erase Messages
Single Messages
You can erase a message itself, leaving the Caller ID information.
• While the message is playing, press and release DELETE. The unit erases the current message and announces, "Message erased."0
All Messages
You can also erase all the old messages only, leaving the new messages and Caller ID information.
While the unit is in ready-to-answer mode, press and hold DELETE until the unit announces, "Messages erased."
• New messages can not be erased in this way. To erase new messages, play them then press DELETE during play back.
Here is a link for the manual for your phone:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
May 09, 2009 | GE 29897GE1 Corded Phone
Message Box is full. How do I erase?
Erase Messages
Single Messages
All Messages
Apr 26, 2009 | GE 29897GE1 Corded Phone
Deleteing txt messages on a LG enV2
Hi, try this
Using the Internal Keypad 1. Open the flip and press[MENU]. 2. Press Messaging. 3. Press the Right Soft Key [Options]. l Press Erase Inbox to erase All (read and unread) Messages or Only read Messages in the Inbox. l Press Erase Sent to erase all unlocked messages stored in the Sent folder. l Press Erase Drafts to erase all unlocked messages stored in the Drafts folder. l Press Erase All to erase all messages from the Inbox, Sent, and Drafts folders (except locked messages). You can choose whether or not unread messages will be erased. 4. Select Yes to erase the messages selected. A confirmation message is displayed.
Mar 24, 2009 | Cell Phones
Delete messages
This is from the manual.
Erasing Messages
You may erase messages in the following three ways:
1. Press and release PLAY/STOP button.
2. Press the review and skip buttons to select and play the message you want to erase.
3. Press the delete button, the current message is erased, and the next message plays.
To erase all previously played Messages in a mailbox
1. Make sure the phone is OFF (not in talk mode)
2. Press and hold the delete button until "ALL OLD MESSAGES ERASED" is announced.
To erase a message from the handset :
1. Press the flash/answerer button on the handset
2. Press the play/stop (key 2) on the handset.
3. Press the erase (key 0) on the handset to erase a message during playback.
NOTE: Erased messages cannot be restored.
Jan 08, 2009 | GE 28112 Trio Cordless Phone
Panasonic KX-TG2344 acidental erased message
Sorry, there is no way to undo an erased message.
Sep 08, 2007 | Panasonic KXTG2344 Cordless Phone
GE 29888GE1 Digital Answering Machine Logo
76 people viewed this question
Top GE Lands Phones Experts
Bruce Robin
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
