Question about Logitech Cordless Mouse
When I bought this mouse M305 , followered alll directions with Vista, mouse lights up but no pointer. doesn't work at all. Thank you, Annette
Posted by ahsteadham on
Narseman
    President:
  • 1,082 Answers
Here is step by step with good info.. http://logitech-en-ap.custhelp.com/app/answers/detail/a_id/12155/section/troubleshoot/crid/428/lt_product_id/5484/tabs/1,3,2,5/cl/au,en/kw/
Maybe you don't need this, but if it still won't work after this, then return it as defective.
Posted on May 06, 2011
Anonymous
    New Friend:
  • 29 Answers
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
Tip
Safety first when using a laser pointer
Although a laser pointer may not look it, they can be very dangerous. While they can be a very effective tool for drawing your audience's attention to things in your presentations, using them for other purposes can cause a lot of damage. Following a few simple safety tips will ensure that no one will get hurt while you're presenting.
- Never point your laser pointer at an other person, especially not the face. Just because a laser pointer may not be dangerous when pointed at the skin of another person it is still a good practice to never use it to point at people.
- Never look directly into the laser beam, even if you are sure that the strength of the laser is not high. Even a low powered beam can cause some damage to the eyes. Eye damage can be permanent so it shouldn't be treated lightly.
- Check for reflective surfaces before you present with a laser pointer. If the beam is reflected off an other surface such as a mirror or glass can be just as dangerous as pointing it directly into some one's eyes.
- There is something about a laser pointer that makes people act like children. I have been in many college lectures where a lecturer will use a laser pointer to make emphasis in class and students will ask to play with the pointer. Under no circumstance should you allow someone else to use your laser pointer, especially in a classroom full of people.
If you feel uneasy about using a laser pointer in your presentation you might want to look into using your computer mouse as a laser pointer. Microsoft powerpoint has a feature that will allow you to use the mouse pointer as a laser pointer on the screen. That by far will be the safest laser pointer.
on Jan 29, 2014 | Office Equipment & Supplies
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
Mouse doesn't work. touchpad works fine. lenovo G470
LOL, go into the mouse and touch pad properties and make sure you don't have the mouse disabled or blocked.
Does the point work from the touchpad when you have the usb mouse plugged in? If not you have the mouse pointer disabled. There might be a button at the top of the touch pad in the middle that you press to toggle the mouse pointer. There could also be a set of keystrokes you hit to toggle the mouse. For example I just worked on one last week where you had to Press and Hold the Alt key then hit the F6 key. Function Key F6 had the icon of a finger inside a square which represented the touchpad.
Click Start/Control Panel and look at the mouse and touchpad properties. There may be settings where you can disable one if the other is present.
Apr 08, 2012 | Computers & Internet
How can I change my cursor?
Hi, I was wondering what Operating System you're using. But if you have Windows 7 (this could be similar to Windows Vista), all you have to do is just click the "start button or windows button" on your keyboard.
You will see that there is a search box, please type in "mouse," then hit the "ENTER" button on your keyboard.
You will be directed to the Mouse Properties window, you need to select on the "Pointers" tab, highlight "Normal Select," and click on "Browse."
You will now see the available mouse pointers on your system. You may select the one you want and hit "Open."
You will be routed back to the "Pointers tab" and you'll now see that on the Normal Select, the mouse pointer you chose is now showing. To make the changes take effect, hit on "APPLY," then "OK."
Aug 08, 2011 | Acer Office Equipment & Supplies
M305 Logitech Wireless mouse with nano stopped working on Laptop
This is a difficult one to answer so lets go through it.
You have a M305 thatrefuses to work and your OS says is returning an error.
You've quite rightly checked the Logitech site and found out that it appears to be a common fault as many people are reporting the same issue.
Logitech have not resolved the issue.
All the above are valid reason for retun to the vendor for replacement/refund.
However you WANT to replace a M305 (a model with know issues) with ANOTHER M305 which will have the same issues as Logitech have not resolved the problem.
I will have to think long and hard before giving a definative reply.
Dec 29, 2009 | Logitech Cordless Mouse
Mouse Pointer Doesn't Move
return that , it isn't your pc
Jul 04, 2009 | Computers & Internet
Logitech Cordless Mouse Logo
580 people viewed this question
Top Logitech Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
