Kicker Solo-Baric L5 Car Subwoofer Logo
Posted on May 06, 2011
Underneath the cone there is a black bit that is shaped like the cone but has separated from the by looking at it, it seems it was held together with some kind of glue or sealent the subwoofer is a kicker l5 solobaric and was wondering would be the best thing to repair it with
5 Related Answers
Anonymous
  • Posted on Feb 03, 2008
SOURCE: kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Anonymous
  • 7 Answers
  • Posted on May 24, 2008
SOURCE: installing my woofers
hi there james. What you can do is connect the cables as normal. 2 to the left, 2 to the right. Then at the cable's end you need to mix the red left cable with the right red cable, and so on with the blacks. and its done. Now instead of 4 cables you have two. If you need further explanation please ask
Anonymous
  • 26 Answers
  • Posted on Jun 07, 2009
SOURCE: I have a kicker l5 12
It sounds like the voice coil may have been damaged in which case you'll hav e to get a new speaker.
Anonymous
  • 144 Answers
  • Posted on Mar 24, 2010
SOURCE: subwoofer cone come loose from outer ring
well you can glue it. i have done it in the past. i used the gel super glue and it held up for about 3 yrs.
Anonymous
  • 52 Answers
  • Posted on Apr 20, 2010
SOURCE: i have 2 kicker L5 subs and they are blown the
Yes you replace both voice coils. Get parts from another speaker but has to be equle in quality.
Rear wheel assembly of my bike is shaking side ways
Sounds like loose 'cones' in the rear wheel hub. The cones are cone-shaped nuts that the bearings run against, being held in place within the hub in the 'cup' of the hub. Tighten the cones until there is free rotation of the wheel with no lateral play. Hold the cone in place with the spanner whilst tightening the lock-nut and recheck the adjustment. If you lack the tools take it to your nearest independent local bike shop and they will surely be happy to help.
Aug 25, 2014 • Cycling
Black mark on t.v. Screen
It sounds like you have a separation issue. The material that the screen is made out of is layered on top of each other. What happens is it separates and causes the distortion/discoloration. When you press on it you are actually pushing it back together like a fly paper that doesn't want to stick anymore. There is not a fix for this other than a new tv.
2answers
I can't remove the speaker
Remove the protecting grill in front. Check if the cone is still connected to the rubber band. If not, remove the screws around the speaker. Open the casing itself. Do not forget the screw in the middle of the battery compartment. Remove the bottom cover. Disconnect the 2 wires on the speaker and take out the speaker. It will come out with the plastic protection around it. Looking at the cone now, push up the Carton cone and keep it in place by putting some tissue paper or small cloth underneath. Clean the cone first. Use some rubber cement on the outer edges of the cone and press the rubber back on the cone. Let it dry for an hour and then remove the tissue / cloth, so the cone goes back to its normal position.You can use some extra rubber (those pre-glued strips that you would use to fix a bicycle tire) to make it extra strong. Remount everything back in place and voila....it works again!If your cone is not damaged, the casing most probably does not seal good anymore. Tighten all screws a little more and use plastic electrical tape all around to seal all joints. The bass is produced inside the casing itself and pushed out via a horn. If it is not closed off well, your bass sounds grumpy.
I have the drill, I have the bits...there is something missing to connect both. What does it look like?
Although you posted your question under Chainsaws instead of another tool forum, look at the end of the drill. Is there a hole surrounded by a cone shaped metal end? This is the chock, if you spin/turn it counterclockwise, the opening should widen to accommodate the drill bits, then spin/turn it clockwise to tighten/clamp down on the drill bit. Some drills accomplish this with an l-shaped key that has a small cone-shaped gear on the end that fits into holes on the chock. Some drills have a chockless drill, and you simply hold the end of the drill and squeeze the trigger to use power to tighten/loosen the bit.
Aug 31, 2011 • Garden
How do you install part# 8193768 spinner for kenmore dishwasher model#66517364300?
You should have 3 parts. The spinner, a cone shaped insert and the snap pin. The cone shape insert is the first part to install. Look at the upper spray feed tube in the top of the dishwasher where the old part used to be. Place the cone shaped insert on top of the spray tube through the hole with the flat part on top. Now take the spinner and snap it into the cone shaped insert from the bottom of the hole. Be sure that the swirling vanes are facing upwards. It should snap in. With the snap pin, push it into the insert underneath the spinner. This is what holds the spinner to the insert. Good luck.
Jun 20, 2011 • Dishwashers
1helpful
2answers
I have a set of technics SB-5000a speakers. one of them the 10" sub is blown. there is no resistance accross it. the cone is in good shape so i think it is the driver. normally you can unscrew the...
if there's NO resistance, see if the lead running to the cone (coil) has broken.
If so, you might be able to solder it back on and save the speaker.
Sometimes they separate at the terminals, sometimes at the cone.
If it separated at the cone, you may need to peel back a bit of paper to get to the wire underneath, and scrape the enamel coating off the wire so you can solder to it.
Otherwise, it's off to your local audio mart to buy a 10" whoofer at the same or higher wattage and same impedance. Take the old one with you to make sure the screw holes align too! (although that's not 100% essential as you can always drill new pilot holes wherever the screw holes aare....unless the screw holes have a metal insert)
If you did have to peel back some paper to do the repair, reinforce the torn area with toilet paper and fingernail polish. Use several layers as you don't want the movement of the whoofer to rip apart your solder joint or any more of the cone.
1helpful
How do I change the instruments lamps on the clock and heating controls on my Avalon Grande 2002 model thanks gary
Gary, as a general rule of thumb you should be able to look around and find the Phillips head screws then carefully pry the panels loose. The screws can be underneath and some times you have to pull the ash tray or other trays out to see them. Those dash assy are put together in interlocking pieces and held in place by clips. Once you get the cover off the instrument assy you should be able to remove the entire cluster (may be screws holding it in place or clips. Look around for screws and things that look like they "fit" together.Generally the panel over the radio ansd heaters is held in by clips and a flat screw driver covered with a rag (to prevent scratching) is good to remove it. If something seems hard to get off look around for screws.
24helpful
3answers
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 • Vacuums
3answers
Hotpoint Aquarius WF 240 Front loader
first remove the soap drawer, this should expose locating holes for screws, remove these first, then remove the screws from on top of the plastic front panel and then the plastic front panel tilts forward to remove, taking extra care with wires etc the soap drawer is now loose still attached to the rubber pipe, which is now easy to get to for inspection, or removal to clear it out. first of all just check that the machine drum is not filling up totally so it is overflowing back out of the soap drawer, if so that is a different fault entirely and does not need taking to bits the same
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
