Question about ROL Wheels Volant
What kind of cassette comes with the Rol Volant. It sounds kind of noisy. Should I replace with a Shimano 105 cassette that I have.
Posted by another56 on
David Dunn
    Brigadier General:
  • 8,546 Answers
If you mean the noise while coasting, cassettes don't make that ratcheting noise. The pawls in the hub/cassette body do. Changing the cassette will not change the sound.
http://www.rolwheels.com/rol_volant_wheels.php
http://www.rolwheels.com/contact_us.php
Posted on May 07, 2011
Hi I broke my 7 speed cassette I cant find what kind or make it is I would like to put a shimano on it just wanted to know if it would fit the bike is only 3 mounth's old can you help ? Thanks Charlie
Take it to a bike shop and ask them because they have to take some measurements very precicly. They can tell you if it's Shimano, SRAM, or Campy.
Aug 20, 2011 | Cycling
How do i get information and diagrams on rebuild my 105 Hub
http://techdocs.shimano.com/techdocs/index.jsp
or "rebuild 105 Hub" in a search engine
or
http://www.parktool.com/blog/repair-help/categories/hub-service
Lots of instant gratification that doesn't involve a volunteer accepting the challenge,
Aug 04, 2011 | Shimano Cycling
Is there a spring in the Shimano 105 FD 5503 front derailler that could have gone missing?
They don't show it in the 'for after market' breakdown. It wouldn't go missing if the disassembly was no farther than they show. But it COULD break, I suppose.
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/FD/EV-FD-5500_5503-1737B_v1_m56577569830728739.pdf
Apr 18, 2011 | Shimano 105 FD-5503-B/F
I have a Campy 10 Speed Shifter, running with SRAM S60 wheels, it causes some problems when upshifting
If you are running a SRAM or Shimano Cassette, then the spacing will be ever so slightly off. If you want to have precise clean shifting then you need to either replace the cassette body with a Campy one and replace the cassette with campy or get a 10-speed conversion cassette such as those from American Classic. Campy spacing on a shimano/ Sram spline.
The wheels in and of themselves should not make any difference.
Another trick for perfect shifting, make sure that your rear derailleur and shifter match - Campy to campy, Sram to Sram as examples.
Jan 02, 2011 | Cycling
Shimano 105 flight deck diagram?
If this is not the diagram you are looking for, please check techdocs.shimano.com for the proper one.
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/CycleComputer/SI-0045A-001_v1_m56577569830684407.pdf
Oct 04, 2009 | Shimano Cycling
Shimano 105 front derailleur does not change down easily - anyone got a solution?
Try lubricating the cable and housing. If it has much resistance then it will not operate correctly.
Apr 09, 2009 | Shimano 105 Triple Braze On Front...
ROL Wheels Volant Logo
188 people viewed this question
Top ROL Wheels Cycling Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Donald Ayers-Marsh
Are you a ROL Wheels Cycling Expert? Answer questions, earn points and help others
