Sony KV-XR29M50 TV Logo
Posted on May 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Comes on after 30 40minutes - Sony KV-XR29M50 TV
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on May 06, 2011
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005489
Points
237762
Hello
Its picture tube base socket has damaged. Picture tube base socket is one diretly soldered to the base card, which in turn pluged onto the picture tube neck. Its focus control pin will usually get damaged, and this type of fault you describes here will occur. The time taken to clear up picture will vary according to atmosphereic humidty.
You can replace the base card. Unplug the base card from the picture tube base card [do it ver cauciously; not to shake it sideways or up-down - just pull it straight backwards; you may have to apply a little pressure to detach it from the picture tube neck]; resolder it out from the card and go for a new one. Replacing it will solve your TVs problem. OK.
Brake light not working
Well, either it comes on or it does not come on, you say it comes on then you say it does not come on, which is it. If the brake light does not come on at all check the bulb first.
1999 chevy venture won't come out of park
Check if the brake light come on when pressing the brake paddle?, IF brake lights do not come on then replace the brake light switch and the shifter will come out of park.
Aftermarket stereo for 2008 malibu ltz comes on but no sound coming out
did you check speaker wires if you have got them wired up right ???
Maytag dryer motor does not come on . replaced motor still does not come on. the electric element does come on.
Dennis498
This is very strange. Are you sure the heating element comes on?On most models I know of , motor has to be running for heater element to come on. Come to think of it your model has a centrifugal switch (attached to motor )it's probably bad .The heater probably thinks the motor is running.
Give that a try
The screen will not come out and the unit will not play. The blue light comes on to switch from radio/cd/tv, etc. and the red light comes on when you push cd eject, but otherwise it will not play any
MAKE SURE YOU PRESS THE SOURCE BUTTON AS THE SCREEN WOULD NOT COME OUT FOR THE RADIO BUT WHEN PRESSED AGAIN WILL PROBABLY COME OUT FOR THE TV
1helpful
Check engine light comes on
keeps cutting off does not have a check light comeing on
Stereo problems in honda accord 92'
do you have after market speakers? ie subs? if so check the REM connection from the deck to the amp
My 60" mitsubishi tv won't come on
My tv won't come on, it was working perfectly then all of a sudden it started showing timer minutes and it went off. when i turned it back on it wouldn't come.I reset it, it still won't come on, i don't know what to do.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
