Look at http://www.copytechnet.com/forums/kyocera-mita-copystar/16737-fs1118-c6400-error.html
for the answer.
SOURCE: Kyocera FS1118, error code C6400, how do I resolve
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Broken fuser heater lamp wire
The fuser temperature does not rise
after the fuser heater lamp has been
turned on.
Tttt
To resolve you will need a tech to replace parts in the fuser assembly.
