SOURCE: I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel.
No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Testimonial: "Thank you so much for the quick and informative answer. It is greatly appreciated. "
SOURCE: maytag mdb 7100/7160 stopped working (control
FYI: In case you didn't know there was a recall about 2 or 3 years back on the panel itself. If you didn't get yours replaced then I would try and see if you still have rights under the recall. If so, they will replace it for free.
I watched the repairman replace ours and it seemed quite simple as long as you connect the wires correctly. If I remember right he messed up the first time and had to go back in.
SOURCE: maytag mdb/c-2 some lights
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
SOURCE: Can I download an operations
http://www.ajmadison.com/ajmadison/itemdocs/PROOF6920183A_MDB-6.pdf
There's the manual!
