Question about Konica Minolta Di1611
I can't find drivers for my Konica Minolta Di1611 printer for windows 7 64 bit
Posted by kanto324 on
eoinzy 1
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Posted on Oct 28, 2011
  • eoinzy 1 Oct 28, 2011
    ps. the additional x86 driver i was talking about was for the BH164, although i would imagine that if you installed the BH162 x86 drivers it would allow the server to see the info that way
William Walker
    New Friend:
  • 14 Answers
Unfortunately, the manufacturer will not support 64-bit drivers for that printer.
http://kmbs.konicaminolta.us/content/support/vistasupport.html
Note: This is the Vista support page, but the driver architecture is the same for Windows 7, so they will be compatible.
Posted on May 06, 2011
Kyle Emson
    New Friend:
  • 6 Answers
Hi Kanto324
There hasn't been a windows 7 driver released as yet for this model. I would try using a Vista driver, It should do the trick.
Thanks
Konica minolta c350 doesn't working in windows 8
Download the PS version for printer driver on to konicaminolta support.
Mar 22, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
Feb 19, 2013 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di1611/Di2011 printer Driver CD has no Driver for windows 7 64 bit - What is solution?
This is a very old post; however, maybe someone could use my help :).
The Konica Minolta Di2011 can be ordered with a built in printer module or not. The difference is that when you have the printer module, it works on PCL, but if not, it will only work using a GDI emulator.
For Win XP, you can find very easily the drivers on Konica website.
The drivers for Win7 64bit, especially the GDI Emulation for DI2011, cannot be found on the website.
I have found on the Konica Minolta website the STD GDI emulator for some other models and I have tested the one for the printer Konica Minolta 162.
It seems it works without problems for now, however I was only using it in A4 mode - manually selected. I have found that it requires a manual selection of the paper size and tray as it will not switch automatically.
I hope this helps.
BR S.H.
Mar 06, 2012 | Konica Minolta Office Equipment & Supplies
I cant find the driver for my konica minolta Di1611 for windows xp. can you help me download it's driver?
Konica Minolta Photo Imaging, Inc. ceased its Camera Business Operation as of 31 March, 2006, and since 1 April, 2006
Sony Corporation has been providing customer service for Konica's, Minolta's, and Konica Minolta's cameras (excluding Film-in cameras) and camera-related products except for the binoculars.
Please be informed upon the termination of the Agreement between Sony Corporation and Konica Minolta Photo Imaging, Inc..
Konica Minolta ceased the entire customer services for Konica Minolta cameras and related products, as of 31 December, 2010.
After 1 January, 2011, the Repair Service Providers will continue support for the repair service independently.
To view the list of Repair Service Providers for each region, please click HERE.
Aug 15, 2011 | Computers & Internet
I can't find drivers for my konica minolta Di1611 printer for windows xp. can you help me download it's driver?
Aug 15, 2011 | Office Equipment & Supplies
We want to set out printer so that it defaults to balck and white printing all the time
There are monochrome only printer drivers on the Konica Minolta Site at this page (you'll have to scroll around on the page a bit to find them)
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm
for example, the driver for Windows 2000/XP is downloadable at:
http://printer.konicaminolta.net/drivers/windows/2430dl_xp_mono.exe
Aug 11, 2011 | Konica Minolta magicolor 2430 DL Laser...
I have a Konica Minolta Page Pro 1300W Printer n I m running Windows 7 Ultimate 64 bit. Please help me running this printer in the given OS. Prabesh Lal Joshi Nepal
Konica Minolta PagePro 1300W is not compatible with Windows 7 64-bit.
According to the printer manufacturer's website the expected driver release date for Pagepro 1330W was July 2010. Check here.
May 28, 2011 | Konica Minolta PagePro 1300W Printer
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
I want the site the download this konica minolta pagepro 1400w printer driver for windows 7 please send the immediately thank you ..,
Specific drivers for you printer are available for Windows 2000/XP, Windows 9x/ME, Windows Vista 32-bit and 64-bit, Windows and Windows XP 64-bit.
A listing of Windows 7 compatibility is available here:
http://kmbs.konicaminolta.us/content/support/windows7.html
The list shows that there should have been a Windows 7 compatible driver by June 2010. There is no specific Windows 7 driver for your printer; however the site does provide a Universal Printer Driver
http://kmbs.konicaminolta.us/content/support/universaldrivers.html
Dec 23, 2010 | Konica Minolta PagePro 1400W Laser Printer
No driver found for Pagepro 1300W for Windows 7 64 bit, are there any solutions? Thanks alot
Use the Vista 64 bit driver. konica Minolta drivers are/will be part of the system 7 load.
Jan 04, 2010 | Konica Minolta PagePro 1350W Laser Printer
Computers & Internet Logo
7,039 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
Tom Chichester
Terry
Terry
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
