Question about Fisher Price Power Wheels Barbie Jeep
I charge the barbie 12 volt jeep and get nothing. i also got two 6 volt batteries and wired them in series bypassing the original batteries but still nothing,are these fused?
Posted by scott_eve130 on
as3power
    New Friend:
  • 18 Answers
I know you are technically strong to do the bypassing part. But assumption is to do with fuse.
Your Power Wheels® 12 volt battery is equipped with a built-in thermal fuse. The thermal fuse is
a self-resetting safety device which automatically "trips" and shuts down operation of the vehicle if the vehicle is overloaded or the driving conditions too severe. Once a fuse has "tripped", remove your foot from the pedal and wait approximately 25 seconds before operating the vehicle again. To avoid repeated automatic shut-downs, avoid severe driving conditions.
better call up Fisher price, and lay back with free mind.
Posted on May 06, 2011
How to wire rhe batterys for 24 volts... Example pos. To pos. Or neg. To pos. Ther are two batterys 12 volts
if you want the same voltage but with increased capacity connect positive to positive and negative to negative on each successive battery ---connected in parallel
example 6 X 12 batteries each of 200 crank hours will be equal to 12 volts and 1200 crank hours ( good for mobile fridges , winches , battery hoists etc)
if you want to increase voltage in the bank then connect positive to negative for each successive battery ---connected in series
for example
with 6 X 12 batteries of 200 crank amps you will have 6 times the 12 volts which equals 72 volts and the current flow is increase from 200 crank amps to exceed the 1200 crank amps because of the electrical principles and formula I think it works out to be around 72 times the 200 crank amps ( I am sure that there are mathematicians out there that will adjust the sum to make it correct)
However I think that you get the idea
when charging batteries it is always positive to positive with the battery leads to the first battery in the bank and the difference is if in parallel the charger has to be big enough the charge at the accepted rate of the batteries ( 12 volts charge at 14.5 volts and around 20 amps an drop back as the batteries charge
when the batteries are in series it all changes and best talk with a good battery supplier as to how it is set up and if you need to change the charging circuit and equipment
Jul 19, 2015 | Cars & Trucks
1993 Jeep Wrangler charging problem
nothing wrong with the ECM unless it has the voltage regulator as part of the system
indicates faulty wiring and faulty alternator
have a load test done on the battery
have an auto electrician do a full charging system check
charging voltage should be 14.5-14.8 volts DC
battery voltage should be 12-13.5 volts dropping to 11 volts when cranking the engine
make sure that the drive belt tension is correct and the belt is in good condition
Dec 22, 2017 | 1993 Jeep Wrangler
Ezip 500 won't run : new batteries fully charged but it still shows low battery light...what else could be wrong
i'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harnedd to new harness to fit bike. Works great.
Jan 02, 2013 | UPG New Replacement Batteries 4 EZIP E Zip...
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
I have changed the alt and regulator,I have power at the alt and the regulator and the relay clicks when the alt is pluged in but still wont charge,same problem I had with the original alt so I gont a new...
One thing you need to check is all the grounds and the positive lead coming from the battery. Cut the insulation back at both ends and check for corrosion. If the wires green or dirty, i'd reccomend replacing the wire. Corrosion on battery wires on the terminals or on the alternator side, will keep the alternator from charging. Make sure the grounds aren't loose and aren't too corroded either. This may not be the problem, but its definitely a probable cause and wouldn't hurt to look. Just my two cents.
Jul 09, 2011 | Fiat 124 Cars & Trucks
What is the expected output of a alternator in a Jeep 4.0L Sahara (yr. 2000)? My Jeep's ''check gauges'' light came on, and the battery gauge dropped to nothing. Checked the alternator (with a voltage...
You shoulld expect more than 12.8 volts from the alternator up to nearly 14 volts when charging a low battery. The battery can only show the amount of voltage your alternator is sending to it after being used for a while. I would suggest that you have the battery tested & recharged completely, your voltage will be above 12 volts and if it returns to below that , you will know your alternator is not charging. Also, if you test the output of the alternator and see it is below 12 volts after the battery is fully charged at 12+ volts you will have confimed the problem also.
good luck.
Jan 31, 2010 | 2000 Jeep Wrangler
No power supply to gearbox
It has a thermal fuse. Depress the gas pedal for 25 seconds and try it then
Jan 02, 2009 | Jeep Yellow Sports Outdoor Power Wheels...
Need a wiring diagram for a barbie 12 volt two battery jeep !!!!!
When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
Nov 25, 2008 | 3d Rose Londons Times Funny Society...
Fisher Price Power Wheels Barbie Jeep Logo
878 people viewed this question
Top Fisher Price Toys Experts
NOEL
NOEL
Marvin
Marvin
john h
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
