Hi wasiullahkha,
I see that you connect your Mobile phones to your Router, but you ge an error using your Nokia e90.
> try to check the wireless setting for the Router.
>this is possible that the Router is set to provide wireless only to deivces that are registered on the Linksys settings MAC address.
>try and check the setting in the Linksys Router possibly MAC Address Filtering check if it is enabled if it is then that will be the cause, you will just need to get the MAC Address of your E90 phone and register in the Router settings for the wireless to work and be detected by the phone.
Or check to see if he router is set to be discoverable or not by other devices , if it is not set to be discovered or the SSID is hidden then you cn manually input that info on your Mobile phone.
these are the only options in a Router that can cause devices not to detect the router signal right away.
I hope that his helps.
Have a nice day,
mvincentc
Thank you for your precious time.
I have found that under option "MAC ADDRESS CLONE".
Should i disable it or write their my nokia e90's WLAN MAC ADDRESS??
Yup you can disable that, that should make the wireless detected for your E90 mobile phone.
I have disabled that MAC CLONE ADDRESS option...But still same error WLAN cannot connect.
I tried to write their my e90's WLAN MAC ADDRESS but it also didnt work.
Is their a possibility that my ROUTER is not compatible with my nokia e90???
PLEASE HELP!!
Yes...There is an aption under MAC's ADDRESS CLONE..and it is enabled....Should i DISABLED this option or write their my NOKIA E90's MAC ADRESS???
