BenQ Joybee 130 MP3 Player Logo
Question about BenQ Joybee 130 MP3 Player
When i start my joybee 130,it goes(no,even it jumps) to "settings" & i cant play any mp3,because i dont accsess to main face!
Posted by ab_qoreishi on
3 Related Answers
Anonymous
  • 277 Answers
SOURCE: Keeps restarting
Joybee 130 supports MP3 files in bit rates 8~320 kbps (sample rate 8~48 Khz); mybe this is the problem...
Posted on Nov 21, 2005
Anonymous
  • 6 Answers
SOURCE: BenQ Joybee 130 Won't play MP3
To clear this problem, you must use the "firmware upgrader" from the manufacturer. Select the "format data area" checkbox when running the utility. You can download the utility and the instructions here: http://www.benq.co.uk/support/downloads/downloads.cfm?product=722
Posted on Jun 28, 2007
Anonymous
  • 5 Answers
SOURCE: joybee 130 MP3 plaer
What i did was go to a Staples store. bought a two gigabyte card and cardreader for 25$ (canadian) and just drag and drop mp3 files onto card
Posted on Jul 07, 2008
When i connect joybee in my pc, i can not see my files
umm are your files on the mp3 players hard drive or on an SD card?
if they are on the harddrive, plug the usb cable into computer and mp3player, go to 'My Computer' there should be a new drive found called Joybee '130 (E,F,G,etc:)' double click this drive, withinn the drive should be three folders, FMRadio, MICIN, and MP3, double click mp3, drag and drop (or copy-paste) the mp3 files into the folder and you should be good.
If your files are on an SD card, you will need an SD cardreader, plug the cardreader into the computer, and again drag and drop(or copy-paste) the mp3 files onto the card
2answers
Joybee 130 MP3 plaer
Plug your player into your computer via USB. If Windows recognizes it, a new drive should show up under "My Computer". It may be called "Removeable media". It may be some letter like "G" or "H". If you have an SD card bigger than 512 MB, then find the removeable drive that is bigger than 512 MB that shows up when you plug in your MP3 player and that drive is your SD card.
Joybee 110
What do you mean by "from then on i cannot use my jb110. " Have you tried to reformat it before you try anything else?
3answers
Hello!!
you likely have a music file other than an mp3 on there ( possibly wma or m4a file) i had a bunch of wmas on mine and wouldnt play, deleted them and added mp3 files and mine worked fine.
No continuous play
hold mode button for a few seconds, then select the play mode option, then select how you want it to play thruogh songs, that may be the problem..
2answers
Well, I have the exact same problem. Occasionally I can get an MP3 to play, but it only works if I play the radio for about 10-15 minutes and then play an MP3. Sometimes it will work, sometimes it won't... Sorry I can't answer it completely, tho.
Internal 512 is invisible
There is a switch on the SD card that allows you to lock it. Check if the switch isn't on the "locked" position, that might be what's making its content inaccessible. Hope this solves it!
Record
sorry I dont understand what your asking please refrase.
Problem with playing Mp3s
Use the "Benq Joybee 130 Firmware Download" program and chose "Format Data Area" in the "Download Options" panel. You can download the program from here: http://benq-eu.com/support/downloads/downloads.cfm?product=722&page=downloads&dtype=B
2answers
Keeps restarting
Top BenQ Audio Players & Recorders Experts
Marvin
Marvin
Are you a BenQ Audio Player and Recorder Expert? Answer questions, earn points and help others
