No, verizon only can supply puk code and lg ally unlock code for you. The only thing that you need to unlock lg screen pattern is reflash your phone at mobile repair shop.
Yes, Verizon will help you with this.
You may need to reset the phone to get in without knowing the pattern lock. To do this (you will lose your saved phone numbers and any stored data!!), follow the steps:
1. Remove battery, then reinstall battery.
2. Hold Volume Up, Home and Power buttons for several seconds, until you see the setup screen.
3. Follow the prompts to set the phone up again.
I found the following on another website. I don't know if it's true.
One thing unique about Android phones is their pattern unlocking system. However, after a number of unsuccessful tries, it will lock you out permanently. This happened to my brother, and it wouldn't accept his gmail username and password (the only other login method). He was looking at a reset and loss of all his data not stored in his Google account. Luckily, he found a work around. If you enter your gmail account name, and use "null" as the password, it will enable the pattern unlock again.
This may give you a chance to try different patterns until you find the one you set.
