Computers & Internet Logo
Anonymous Posted on May 06, 2011
I have a proview 3200 wall mount, when I attach the cable there is no picture. I just got this from someone so I have no manual or know if it isn't working. THe set up screen will come on and I can select through items.
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on May 06, 2011
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191031
Points
2336
I assume you are connecting to a computer. Does the proview provide type of input? You want to select the correct input such as VGA.
  • 1 more comment
  • Anonymous May 06, 2011
    I just tried to put the cable into the back and see if I could view regular channels. I have not yet connected it to my computer. Is this product capable of being used like a TV?
    Does it have an input for cable TV? If so, then is should. Looking on the Internet, there are many different variations of Proview 3200. Post the exact model and I will get you more information.
    Product # RX-326
    Model # 3200
    Serial # FOA259042848C
    Thank you :)
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
2answers
Is there a wall mount kit I can purchase for my Proview 3200 326
There are pretty much wall mounts for every flat screen tv out there. Target sells them. You just purchase by using the size of your tv and there should be brackets that match the screw slots on the back of your tv.
Can an ILO flat screen be mounted to a wall
Yes it can as long as it has the screws in the back of the unit for the wall mount to be attached. You can call your manufacturer and retrieve the model number to the type of wall mount you desire. You can purchase a wall mount directly from manufacturer website or if you prefer can buy it from your local electronics retailer.
Proview tv... 1080p????
if it has either hdmi out,,or comonent out,,then yes,,probly 1080p,,or at least 720p,,thats good
2answers
No picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
2answers
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Grand Canyon Tech
Grand Canyon Tech
