Question about Bunn GR10 Coffee Maker
We unplugged our Bunn and left it unplugged overnight to do some painting. When we plugged it back in the light doesn't come on the warmer and the water does not heat.
Posted by pjclark77 on
RJ Keck
    Novelist:
    Scholar:
  • 166 Answers
The unit is not getting power. If the receptacle is protected by a GFI, then press the Reset button. Otherwise, check that the circuit breaker (or fuse) to that receptacle isn't tripped.
Posted on May 26, 2014
4 Related Answers
Anonymous
  • 9 Answers
SOURCE: I have an older Bunn-o-matic
Here are some possible causes ,the hi temp cut out ,thermostat, or heating element are bad .a continuity tester can determine whitch one .Also you could have a burnt off wire . The reason the water is still luke warm is a electic warming jacket that bunn put around the water tank to limit the therostat cycles during off peak usage very fixable hope this helps
Posted on Jan 06, 2009
Harry Presley
  • 193 Answers
SOURCE: My bunn stopped working completely.
Plug something else into the same outlet and see if you are getting electricity in that outlet. If it is on a ground fault circuit, push the little red button in in the middle of the outlet. or check the breaker box to see if the breaker has kicked. It is unusual for everything to quit working at the same time if it is getting power.
Posted on Sep 08, 2010
Darryn O'Neill
  • 115 Answers
SOURCE: bunn-o-matio model btx-b does not heat water
Hi, Sounds like a boiler therostat or faulty boiler. Dazza REPAIRER
Posted on Sep 24, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: my bunn coffee maker
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Posted on Oct 23, 2011
Month Old Bunn smells hot
Bunn machine smells hot
* Check for unusual sounds from brewer (other than sizzling from warmer plates). There should be a gradual boiling sound accompanied by some steaming at the top of brewer. This will turn off and ready light indicating the brewer is ready to brew.
* You may sometimes hear a slight boiling sound from time to time (about 15-30 mins apart). Notify your vendor as the warmer blanket may be out. (your brewer will still work but call them anyway.)
* Check your manual for setting up procedures and checks. It's available on line: http://www.bunn.com/product-manuals
* Constant boiling (more than 15 mins) with lots of steaming is a sign of an electrical problem. Unplug machine and call vendor for service.
* Final; Unplug unit and check for 'stuff' in pour over tray. I've found Chocolate, Cream, Milk, powder, sugar, honey, and a dead rat in the tray. Crew will repour old coffee or beverages into brewer to 're-heat' them. Notify vendor for cleaning or replacement (it happens all the time.)
Aloha, ukeboy57
Jan 17, 2018 | Bunn Coffee Makers & Espresso Machines
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Dec 30, 2016 | Bunn Coffee Makers & Espresso Machines
I unplugged my bunn for vacation and now it won't come back on I forgot about the vacation switch It has always worked fine before.
If it's plugged into a GFCI outlet, press the RESET button. Do not press the "test" button.
If still no joy, plug something else into that outlet and see if it works. If it doesn't, check that the breaker on your main panel for that circuit isn't tripped. If it is, push it all the way to the off position, then back to the on position. You should hear it click like a light switch.
Jul 19, 2014 | Bunn GRX-B
The green light on my prince lionheart warmer won't stop blinking
I realize the original question is 2 1/2 years old but for future answer searchers... the flashing light means your power cord is no longer working.
Jan 18, 2013 | Prince Lionheart Premium Wipe Warmer
Whirlpool interior light won't shut off
That is a really good question....what category did you post it under?
May 28, 2012 | Cars & Trucks
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Bunn Series VPR, pour water in, water comes out cold
Test that you have it plugged into an operating outlet.... Check that all of the switches are "on" (the warmer and the heater switches). If this doesn't help, you'll need to unplug the unit and test the switch and element for proper operation. Both can be tested for continuity. If they all test good, then I'd suspect the thermostat.
Good luck and best regards, --W/D--
Jul 18, 2009 | Bunn VPR Coffee Maker
How to change a start switch, and a lighted bottom element switch on a Bunn Omatic 3 station coffee maker (with a hot water spout on the side)
Unplug your brewer, take the 2 screws off of the lid, lift the lid, and you can see your switches from there.
Removal and Replacement for start switch;
1. Remove all wires from the switch terminals.
2. Compress the clips inside the hood and gently
push the switch through the opening.
3. Push the new switch into the opening and spread
the clips to hold the switch captive in the hood.
4. Refer to the List below When reconnecting the wires
BLU to Timer
WHI/ RED to On/ Left Switch
WHI/ RED to Liquid LevelControl Board
The warmer switch is replaced the same way, just make a note of which wire goes on which terminal when you take it off so you can replace them to the proper place. These switches are easily found at any local Bunn repair shop.
Sep 18, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn GR10 Coffee Maker Logo
391 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
