Hi churris_s99,
The most common caused of this symptom is the bad solder joints in the speaker of the affected parts. If you can take it apart check if one of the wire has it. Another is the open internal wire in the cable of the headseat. You may confirm it using a continuity check with a multimeter. Place the earphone to your ear, upon testing the end of the headset plug you will hear a scratching sound...
To confirm where the fault came from insert another headset to your unit. If the symptom does not appear in the new headset, above was a caused of the symptoms.
Hope I helped you.
Thanks for using Fixya.
