SOURCE: I just bought a Datel
Hi trevinos,
You might already tried this process, but you might want to consider doing it again by following the steps below. Use the included talkback cable to connect the headset to the XBOX controller.
1. First, insert the right angle plug into the mic input jack on the XBOX controller.
2. Insert the straight plug into the "XBOX jack" on the X11 amplifier.
3. Use the chat volume control on the amplifier to adjust the level of XBOX live chat voices from other player.
4. Use the game volume control on the amplifier to adjust the level of the game sounds.
Note: Kindly use the Mic Mute switch on the X11 amplifier to prevent your voice from being heard by other players.
Configuring the Xbox settings:
1. Press the center XBOX button on your controller to bring up the Dashboard.
2. Navigate right to the setting tab and scroll down to "Preferences" from the menu. Press "A" button.
3. On the Preferences screen, select the "voice" option and press "A".
4. Select the "Play Through Headset" option and set the volume to 10.
Hope it helps.
Thank you for using FixYa.
