Garden Logo
Posted on May 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power washer was going then it just stopped while there was still gas
Anonymous
Level 2:
New Friend:
  • Expert 36 Answers
  • Posted on May 05, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
36
Questions
0
Helped
4417
Points
104
Have you checked the oil?
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
2answers
Power boss pressure washer stops when trigger is released
The unloader on yoru pump is bad.. Pressure washer parts catalog quick links Pressure Washers High Pressure... go here with your model number on your pump and they can guide you to your new unloader. Good luck
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
3helpful
Will not start
Power washers are often not used for an extended period of time. This often leads to the tiny passeges in the carburetor getting clogged with the gummy residue left when the gasoline evaporates. It is usually not old gas in the tank that is the problem as much as the residue left behind when the gas evaporates in the carburetor. Cleaning those ports ( orifices) is usually what is needed.
If your machine has a fuel shut-off valve you can save a lot of time , trouble and money by closing the fuel shut-off valve and continuing to pressure spray water until the engine empties the carburetor bowl of fuel and stops. With no fuel in the carburetor the ports will stay clear.
It is suddenly stopped while i am using it for car wash. could you please tell me what is the problem? This is the first time i am using.
There can be many reasons why your pressure washer stopped working. Do you have a gas power washer or an electric one?
Oct 13, 2013 • Garden
Can't start it back up after running
when it stops check for spark the coils go bad
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
We think oil for the engine of our Devap 2600 PSI 50 Gas-Powered Pressure Washer #DVH2600, Honda 5.0 EXH2425 was put in the wrong spot... in the unlabeled orange-cap opening, not the small grey...
To evacuated the oil from what I believe is the gas cap area, you are going to need some type of a siphon pump to remove the oil. A total engine tear down might be needed depending on where all the oil is. Remove the spark plug, and turn the engine over, if you are getting oil coming out the spark plug hole, then you are going to have to either tear down the engine, or leave the engine sitting in a way that you can drain all of the oil out of the system.If no oil comes out of the spark plug hole, then you should be good to go once you siphon out all the oil
3helpful
2answers
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
Top Northstar Garden Experts
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Northstar Garden Expert? Answer questions, earn points and help others
