Ok how do restart a password, - Computers & Internet
rwight
    New Friend:
Quickest way is to restart the whole router
Step 1. Locate the restart button, press and hold for 10 seconds(you may need a tooth pick or something like it ti get to the button)
Step 2 connect to routers using default wep key (usually printed on back of router or in manual)
Step 3 open web browser and type http://192.168.1.1.  This should take you to your router setting menu.
Step 4. Enter defult user name and pasword. Usually this is admin for both but check back of router of manual again if incorrect
Step 4 locate security settings and change passwords
DONE
Posted on May 05, 2011
Pavan Ponangi
  • 390 Answers
There is generally a small pin hole at the back insert a pin and hold the button for 15-2- secondds and this should reset the router to factory settings
hope this helps
G33k
    Guru:
  • 485 Answers
Is this the router password for the configuration page or the password for Wireless internet?
You can access the router configuration page by going to your gateway address, then login. To do this, open up a internet browser, type in the gateway address(usually 192.168.1.1) and login. After you login you can change the wireless password or the admin password for the router.
If you are unable to do the steps above, you can hard reset the router to see if that returns it to factory defaults, however, you will lose any of your settings and most likely have to reconfigure the router.
To do a factory reset, normally, you can press the small reset button located on the back of the router, and hold it for 10 seconds.
For further assistance, you may want to contact technical support from the company who developed the router.
Regards,
G33k
I forget my password pls help
  1. Log on as an administrator.
    1. Restart the computer.
    2. Press CTRL+ALT+DELETE two times, and then type the name of the administrator user account.
      Note If you do not know any other administrator user account, try to type Adminstrator in the User name box.
    3. In the Password box, type the administrator password, and then click OK.
      Note If you do not know the administrator password, leave it blank, and then click OK.
  2. Reset the password.
    1. Click Start, and then click Run.
    2. Type control userpasswords2, and then click OK.
    3. On the Users tab, click the name of the user account that you want to reset the password for, and then click Reset Password.
    4. Type a new password in the New password box, and then type the password again in the Confirm new password box, and then click OK.
    5. Restart the computer, and then try to log on to Windows XP again.
  3. if have any clarifications refer this link :support.microsoft.com/kb/321305
Nov 04, 2010 | Computers & Internet
Tip
Windows XP-based computer if you forget your password or if your password...
<span>To log on to a computer as the administrator to reset a password, try the following steps. <ol> <li>Log on as an administrator. <ol> <li>Restart the computer.</li> <li>Press CTRL+ALT+DELETE two times, and then type the name of the administrator user account.<br /><br /><b>Note</b> If you do not know any other administrator user account, try to type <span>Adminstrator</span> in the User name</b> box.</li> <li>In the Password</b> box, type the administrator password, and then click OK</b>. <br /><br /><b>Note</b> If you do not know the administrator password, leave it blank, and then click OK</b>.</li></ol></li> <li>Reset the password. <ol> <li>Click Start</b>, and then click Run</b>.</li> <li>Type <span>control userpasswords2</span>, and then click OK</b>.</li> <li>On the Users</b> tab, click the name of the user account that you want to reset the password for, and then click Reset Password</b>.</li> <li>Type a new password in the New password</b> box, and then type the password again in the Confirm new password</b> box, and then click OK</b>.</li> <li>Restart the computer, and then try to log on to Windows XP again.</li></ol></li></ol></span>
on Nov 23, 2010 | Computers & Internet
How do i reset my password on my hp mini 110. someone changed it and we can't get back in
assuming you have xp and there's no admin password try the following:
1. turn off your laptop
2. restart your laptop and before win xp logo comes on press f8 several times until you get into a black screen with the advance start up options, if you see the xp logo, restart your computer and try again.
3. select with the arrow safe mode and press enter to start your computer in safe mode.
4. before you get into windows will be prompted to select an account, if you had an account, should see your account and an administrator account. select the administrator account to log in.
5. Once in windows under the administrator account proceed to reset your password as follows:.
I hope that helps!
Apr 17, 2010 | HP Pavilion 110-1030NR Notebook
I have forgot my password for my sony laptop
Restart your pc and press F8 as soon as logo appears and select safe mode. now it will go to safe mode . there press CTRL+ALT+DELETE keys and give user name Administrator and enter without password. now you can access your profile and reset password, restart your pc and go to windows noramlly and login..thats it.if its not solved jst ping back , will send the software to break the password..ok
Feb 02, 2010 | Computers & Internet
How to break admin password without bootable cd?
Hi
OK
RESET IT
YOU GO ON SAFE MODE AND CREATE A NEW ACCOUNT WITH ADMINISTRATOR RIGHTS . TO GO IN SAFE MODE PRESS F8 BUTTON WHILE BOOTING WINDOWS. ONCE IN SAFE MODE, CREATE A NEW ACCOUNT, THEN RESTART THE PC. ONCE YOU RESTART LOG ONTO THE NEWLY CREATED ACCOUNT AND GO:
CONTROL PANEL> ADMINISTRATIVE TOOLS> COMPUTER MANAGEMENT> ON LEFT SIDE SELECT LOCAL MANAGEMENT AND GROUP>THEN SELECT USERS>THEN U WILL SEE LIST OF USERS .
RIGHT CLICK THE USER U NEED TO RESET PASSWORD THEN SELECT ALL TASK SET PASSWORD>CLICK PROCEED> THEN LEAVE NEW PASSWORD BLANK AND CONFIRM PASSWORD BLANK THAT`S ALL
OK
Jan 07, 2010 | Microsoft Windows Vista Home Premium with...
User password blocked
gust restart the machine goto safe mode log in to administarator from there goto computer manage goto users reset the password you are using
then restart
ok bye............
Nov 07, 2009 | Computers & Internet
Password Problems
Could you be more specific , which password are you talking about. Does the system prompt you for the password after the windows Xp screen loads or at Dell logo screen.
If its a problem with the windows xp password, you can try the following option
1. Restart your computer at the Dell logo screen tap on the F8 screen 5 - 6 times
2. Select safe mode from the advanced options menu
3. Hit enter
4.Hit enter again
5. Select adminstrator login
6.Reset the password. a. Click Start, and then click Run. b. Type control userpasswords2, and then click OK. c. On the Users tab, click the name of the user account that you want to reset the password for, and then click Reset Password. d. Type a new password in the New password box, and then type the password again in the Confirm new password box, and then click OK. e. Restart the computer, and then try to log on to Windows XP again.
Note : If you donot have the adminstator account , then you might need to reset the computer to factory defaults.
Thanks
proton
Nov 04, 2008 | Dell Inspiron B120 Notebook
Forgot the log on password. need to recover the password or bypass to log on
here is one way for Windows XP
first, you have to log on as the administrator
If the administrator password is set to a blank password, do not type a password before you click OK.
Then you have to RESET the password
Click Start, click Run, type control userpasswords2, and then click OK.
Click the name of the user account that you want to reset the password for, and then click Reset Password.
spin
Jul 14, 2008 | Computers & Internet
I have forgotten my administrator password
  1. Reboot Windows in Safe Mode. To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
  2. Click Start, and then click Run.
  3. In the Open box, type the following command, and then click OK: control userpasswords2
  4. Click the user account that you forgot the password for, and then click Reset Password.
  5. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Jan 03, 2008 | Microsoft Windows XP Professional With...
I can't get on my computer
Computers & Internet Logo
41 people viewed this question
Ekse
Marvin
Marvin
