Question about Microsoft Xbox 360 Console
I just got a transcend jetflash 620 16gb usb drive and my xbox 360 does not pick it up although it is formatted in FAT32 and i am also using a transcend jetflash V30 4gb which works perfectly fine, why so and please give me a solution for the 16gb one !
Posted by ayush_bull on
Chip_E
    New Friend:
  • 47 Answers
Follow the instructions for formatting the flashdrive on your Xbox here. Simply formatting it on your computer is not sufficient and you may have forgotten that you did this step for your smaller flashdrive. As you can see in the link, Xbox supports up to 16 GB so you may not be able to use all of the space if your flashdrive is any larger than is supported. Flashdrives are not the size they are marketed to be and tend to be smaller than advertised but it would not be unheard of for it to be larger. If this is the case, you will only be able to use a portion, albeit a very large one. I hope this helps and have a nice day!
Posted on May 05, 2011
How do you make it connect to you xbox 360?
Plug the usb into the back of the xbox and click through the onscreen prompts
May 24, 2015 | Transcend TS16GJF200 16GB JetFlash 200 USB...
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
Dec 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4gb pendrive was unable to format .While formatting option ,it shows only 8mb
Try to format with NTFS option. Sometimes FAT32 file system has a problem with big memory stick. Around 4 GB is FAT32 limit. Or maybe flash has some hardware failure, because memory cells from flash card has limited write cycling. Some of them have controller for using of good parts, but sometimes it has too much bad sectors.
Aug 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hi, i can't download some files to my transcend elite storejet 500GB, it's says the file is too big, but the file is just 5.49 GB and free space in hard drive is more than 400 GB. what to do?
You drive is formatted for FAT32. What that means is the way data is stored on the hard drive is an older method that does not support files over 4GB. The benefir of FAT32 though is it can be read and written in both Windows and Mac. If you hate mac (as we all do) then screw FAT32. I almost forgot, if you use this hard drive with the xbox 360 do not continue as the xbox 360 for some ******* reason 360s can only read FAT32. The new format we are going to go to is called NTFS (new technology file system) which is made by microsoft, makers of the xbox 360. lol
Anyway first backup everything you have on that disk. Either on a computer or burn it to DVDs cause if you don't you will lose everything.
Plug in the drive, right click on My Computer (or its just "computer" now) click manage. Go to disk management on the left pane. It will take a minute to detect all your drives. You will see your 500gb drive. Double and even triple check it is your transcend drive. Right click it and click format. Change File System to NTFS.
Apr 06, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
Memory card decreased memory
you have either formatted it as 2 disks or the card is developing faults. Check the number of disk volumes in Computer Management. If only 1, throw the card away. (Make sure it is formatted as NTFS, or FAT32 NOT FAT.)
May 26, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Microsoft Xbox 360 Console Logo
648 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
